Bipolar Parallel is the best possible wiring for what you need,.Cutter07 wrote: Would the way I have the stepper wired (Bipolar Parallel) be an issue? I chose this because I was reading that high inductance can cause stepper motors to stall at high RPM. Also I forgot to mention that I have a 48VDC power supply, but from the torque chart 900 RPM should be achievable.
