How to square a Precix 4'x4' 5100 CNC?
  • quarklark
  • Topic Author
  • New Member
  • New Member
5 years 11 months ago #190013 by quarklark
How to square a Precix 4'x4' 5100 CNC? was created by quarklark
The gantry on our machine is out of square by 0.372 degrees, but I' can't figure out how to adjust the cross beam? I've tried loosening the bolts on the right hand side of the machine and tapping it over, but it looks like there's no room for the bolts to adjust.
Does anyone have a manual for this particular machine? The details I've collected so far are here: github.com/quarklark/GSS-CNC/wiki/machine-specifications
Thanks!
5 years 11 months ago #190019 by rodw
Replied by rodw on topic How to square a Precix 4'x4' 5100 CNC?
For Linuxcnc V2.8 and above, this can be squared in the homing sequence just by altering the home offset on both sides of the gantry.
eg if there is 5mm error from one side to the other, you need a home offset that is 5mm different each side.
  • quarklark
  • Topic Author
  • New Member
  • New Member
5 years 11 months ago #190055 by quarklark
Replied by quarklark on topic How to square a Precix 4'x4' 5100 CNC?
Thanks so much for the quick reply!!
Our system only has a single driver on the gantry, which is tethered to the opposite side with a drive shaft. (It's a rack and pinion drive.)
This is our .pncconf file: github.com/quarklark/GSS-CNC/blob/master.../PRECIX_MESA.pncconf Is there a particular property that I should try setting?
5 years 11 months ago #190078 by rodw
Well, if you can't square the hardware, it is possible to create a component that applies an offset to the Y position, based on the X position so it can track squarely. I did help someone to create such a component once previously and the details are somewhere on this forum. It was for a 3 axis mill.
5 years 11 months ago #190085 by Clive S
Replied by Clive S on topic How to square a Precix 4'x4' 5100 CNC?
rodw wrote: Well, if you can't square the hardware, it is possible to create a component that applies an offset to the Y position, based on the X position so it can track squarely. I did help someone to create such a component once previously and the details are somewhere on this forum. It was for a 3 axis mill.
Its uses millkins
wiki.linuxcnc.org/cgi-bin/wiki.pl?Contri...y_XY_skew_correction
5 years 11 months ago #190086 by rodw
Clive S wrote:
Its uses millkins
Thats a different method again to what we did. I think we probably used external offsets.
5 years 11 months ago #190103 by Clive S
rodw wrote:
Clive S wrote:
Its uses millkins
We used millkins about 5 years ago and its still working today If I remember it was using Lcnc 2.6
5 years 2 weeks ago #223236 by CNCMELILLA
Replied by CNCMELILLA on topic How to square a Precix 4'x4' 5100 CNC?
Buenas tengo una CNC PRECIX y cuando muevo el carro en X - Y - Z los tres ejes todos los movimientos dan unos pequeños saltos y hace unos pequeñas palpitaciones no muy agradables el problema es de configuración del ordenador de la CNC que mueve la fresadora yo creo q es por la regulación de paso a paso
ya que instalo un disco duro clonado que tengo que me da (otro fallo anterior) y que tampoco se reparar, pero cuando la muevo para los lados va perfectamente pero vuelvo a poner el disco anterior con el que puedo trabajar y vuelve a dar las palpitaciones que no es nada agradable escuchar la máquina trabajando a sí ,
abría un técnico que pueda repararla por remoto? por favor estoy desesperado ya con esta situación ya que precix no me hace ni caso
5 years 2 weeks ago #223338 by andypugh
Replied by andypugh on topic How to square a Precix 4'x4' 5100 CNC?
Maybe try asking here too?
forum.linuxcnc.org/45-espanol
Time to create page: 0.063 seconds
