Hey guys,
Long time reader as I waited for the right opportunity to buy a machine, which just happened. I recently picked up an obscure Folken M3400E minimill with dead drive electronics, which needed modernization anyways. The BLDC servos are unlabeled but if I did the math off the spec sheet, it's a 1000 line encoder. I have a set of AMC DR101EE20A8BDCA drives that I was going to use with the power supply, which, has a number of inputs. It would seem the step/dir would be my best choice.
At the moment I'll be using the also-supplied NSK Astro-E spindle, which I understand needs 0-10V for speed and driven through a couple 24V logic controls for direction and enable. In the near future, I expect to get/build a different spindle setup. I would like to retain/side mount the NSK spindle for where it's best (high rpm micromachining applications), albeit not to be used simultaneous the other spindle, so some sort of switch on the 0-10V would be a definite possibility.
Touch probing of some sort and tool length measurement are definitely happening soon. End goal would be to add linear scales and a 4th axis, but I'll address these later.
Questions:
1.) What control board is recommended? Starting off that's some limit/home switches, microswitch for tool length probe, a couple relays/fets to run the spindle, 3 channels of step/direction, and the appropriate controls for 0-10V spindle. But want to design around anticipated expansion.
2.) Does it make sense to bring the rotary encoder back to LinuxCNC or treat the drive controllers as "super steppers" since they have their own control logic?
2.) Any recommendations for a decent 0.6-1 kw 6k-10k rpm motor/drive combo (compact/lightweight) to belt drive a Finley er16 spindle that I got for a screaming deal? Ideally I'll have a 2 belt ratios for up to 15K (single flute small bit stuff)
Thanks,
Daniel
finleyprecisionspindles.com/36-air-motor...-belt-drive-spindle/
www.nsk-nakanishi.co.jp/industrial-eng/d...E_Rev_3_E400_500.pdf
