Brother TC-225 Retrofit and Robot integration
5 years 4 months ago #211894 by PCW
You can use 7I77 field inputs 1,2,3,4 as analog inputs to read a potentiometer
5 years 4 months ago #211927 by timfaber
PCW wrote: You can use 7I77 field inputs 1,2,3,4 as analog inputs to read a potentiometer
Sorry forgot to mention I have the 7i97. There are no analog in pins on there unfortunately
5 years 4 months ago #211934 by PCW
A 7I73 is a possibility if you are not using the sserial port expansion
5 years 4 months ago #212149 by andypugh
No eBay APP ID and/or Cert ID defined in Kunena configurationIf you were to swap the potentiometers for MPGs then things would be easier. There are potentiometer-format encoders readily available.
MPG encoders play better with other override sources than potentiometers too.
This sort of thing:
5 years 4 months ago #212166 by PCW
The 7I97 can have up to 4 hardware MPG encoder counters
5 years 4 months ago #212342 by timfaber
Ah that's great. Will use mpg's then, thanks for the advice!
Time to create page: 0.098 seconds
