i would stick to a way oil they have additives referred as tackifiers to keep the oil from running off. i used grease at first but had problems with the grease not letting things roll and they slid instead causing problems. the cheap ball screws with the plastic ball returns did not like the sliding caused by grease in my case. Vactra way oil no, 2 and ISO grade 68 should be the same they are just different classification systems. Vactra no,2 is pretty common on the commercial machining centers.
