Harrison M280 CNC Lathe, Setting up Threading using phototransistor
4 years 10 months ago #228699 by Todd Zuercher
When doing manual work do you intend to still have Linuxcnc running? Or do you want to have the PC off? It may be good to keep Linuxcnc running so you can still use it for DRO and power feed purposes, and if that is the case you can use the onscreen controls that are built into the GUIs for manual control of the spindle and coolant.
4 years 10 months ago #228729 by andypugh
I have three position switches (off-auto-on) for some features of my lathe. But the logic is handled in HAL so requires that LinuxCNC be running.
Physical switches are probably the only way if you don't want to have LinuxCNC running.
4 years 7 months ago #238423 by PhilCNC
Hi PCW, I have my machine setup with a spindle encoder and I'm trying to cut threads now, but the RPM signal is bouncing around a ton, like plus or minus 150 RPM. And my threads turn out inconsistent. Any advice?
4 years 7 months ago #238434 by PCW
Is the counting precise?
That is, if you turn the spindle say 10 turns by hand, do you get exactly
500 counts?
4 years 7 months ago #238437 by PhilCNC
It wasn't, I ended up replacing the encoder with a nicer one, and in the end it works ok, it's just a poor surface finish which isn't an electronics issue! Thanks for your help!
4 years 7 months ago #238650 by andypugh
Time to create page: 0.389 seconds
