Bostomatic 400-2 Retrofit
- nduerr
07 Oct 2021 21:30 - 07 Oct 2021 21:33 #222493
by nduerr
Bostomatic 400-2 Retrofit was created by nduerr
Hi All! This is my first attempt at a retrofit. My Bostomatic 400-2 is a 4 axes, 2 spindle (4000rpm & 30000 High speed), 16 turret tool changer model. Luckily it was converted to a PC control back in 2004, however in March I had a servo amp fail and it must have back feed back into one of the proprietary boards and/or the PC control boards of which I can't find replacements. (Bostomatic and the Retrofit company are out of business).
I have all schematics for the original and retrofit so that is helpful. I am planning on reusing as much as possible of the original equipment initially and upgrade when I can.Luckily, with the earlier PC conversion, all the relay and control items were run through 2-24 port WRC Acron (similar to opto-22 boards) that I believe will plug directly into a mesa board. If I am not correct about this let me know! I would like to keep my Servos and spindles on different boards so the upgrade track will be simpler. I’m not set on the control panel interface, I am willing to replace the pots with rotary mpgs if they are easier to work with for the manual overrides, suggestions are welcome!I have been going through the Mesa selection and I have come up with 3 configurations that would like to get some feedback on. They are all roughly the same price, so I am looking for performance benefits and or LinuxCNC programing/mapping benefits.
Option 1:
Mesa 5I24----WRC1
WRC2
Mesa 7I44 ----7I69
7I48
4 Servo Drives with Encoders with 2 extra
7I33TA
Main Spindle & HS Spindle
7I69
7I42TA
Control Panel interface
6 on/off switches, 5 position rotary switch
1 MPG, 3 Potentiometers 2 spindles & feed manual
overrides (I’m not sure if this card can take 5kohm pots)
Option 2:
Mesa 7I94
7I69
WRC1
WRC2
7I69
7I48
7I33TA
7I69
7I42TA
Option 3:
Mesa 7I80
7I48
7I33TA
7I44
7I69
WRC1
WRC2
7I69
7I42TA
manual overrides (I’m not sure if this card can take 5kohm pots)
What does everyone think?
Thanks for the help!
Option 1:
Mesa 5I24----WRC1
WRC2
Mesa 7I44 ----7I69
7I48
7I33TA
7I69
7I42TA
Option 2:
Mesa 7I94
7I69
WRC1
WRC2
7I69
7I48
7I33TA
7I69
7I42TA
Option 3:
Mesa 7I80
7I48
7I33TA
7I44
7I69
WRC1
WRC2
7I69
7I42TA
Last edit: 07 Oct 2021 21:33 by nduerr.
07 Oct 2021 23:36 #222503
Replied by andypugh on topic Bostomatic 400-2 Retrofit
My most recent conversion used a 5i24. It's a great device at a good price with lots of pins.
I would tend towards one of your options that includes a 7i44 (or 7i74) as the easiest way to wire your control panel is to put a 7i73 in there and run one CAT5 cable back to the main control box.
- Thank you received: 5332
07 Oct 2021 23:46 #222504
Replied by PCW on topic Bostomatic 400-2 Retrofit
One suggestion for OPTO22 interfaces: a 7I90HD
We have no 7I69 stock and it will be a long time
before we can build them again
A7I90HD with sserial remote firmware can
interface to 3x 24 I/O OPTO22 modules
The only real feature it lacks compared to
the 7I69 is that it does not have the reversed
I/O numbering option that the 7I96 has
- nduerr
12 Oct 2021 19:35 #222962
by nduerr
Replied by nduerr on topic Bostomatic 400-2 Retrofit
Thanks PCW & andypugh,
I am leaning towards the 7I94, 2X 7I90HD for 7I48, 7I33 & 2 WRC connections.
For the panel I am looking at the 7I73.
My main concern is the 3 potentiometers. It looks like the 7I73 has 3 analog inputs, will these work well for the pots?
Also, are there breakout boards for the 2x20 & 2x17 header plugs?
12 Oct 2021 20:04 #222967
They read to 8 bits, ie 0 to 255 on a 3.3V range. So should be fine if you want to stay with potentiometers. You might want to consider swapping the potentiometers for encoders, though. (there are many 16-click encoders available in the same format as potentiometers) as encoders "play better" with other signal sources. A potentiometer, being absolute, always has to "win".
It has 4 analogue inputs, numbered 0 to 3.My main concern is the 3 potentiometers. It looks like the 7I73 has 3 analog inputs, will these work well for the pots?
12 Oct 2021 20:05 #222968
There is no way to get 7I33 or 7I48 support for the 7I90HD in SSerial mode
I would suggest
1 7I94 (ethernet SSerial linterface + 1 25 pin expansion connector)
1 or 2 7I83 (analog +-10V out) (SSerial)
1 7I89 (8 channel encoder interface on 7I94 parallel expansion)
1 7I73 (front panel interface, SSerial)
1 7I90HD (OPTO22 interface, SSerial)
I would suggest
- nduerr
13 Oct 2021 13:18 #223022
by nduerr
The options are getting sifted down!
PCW what are your thoughts on this config, similar to option 3 above?
1 7I80HD
1 7I48 Axis servo control w/ encoders
1 7I33 Spindle control
1 7I44 (8channel ethernet SSerial interface)
1 7I80HD
13 Oct 2021 14:57 #223028
I t should work but lacks some advantages
(analog out isolation, simpler cabling)
and is more expensive than my suggestion
- JR1050
- Thank you received: 31
18 Oct 2021 13:32 #223452
by JR1050
Replied by JR1050 on topic Bostomatic 400-2 Retrofit
I usually use a 7i84 for the operator controls, I think I used it because it has screw terminal blocks . have had issues trying to use analog pots for things like feed over ride, since you can’t exactly get the analog to digital conversion perfect, it eats up a ton of real-time cpu and lcnc doesn’t seem to function properly, that was the explanation that I had read in another thread. What is the pc control that you are removing?
- nduerr
19 Oct 2021 14:28 #223562
by nduerr
It was converted to MDSI OpenCNC (now Hurco) in the early 2000's. Both Bostomatic and the Integrator are out of business so no help there.
As far as I can tell with what testing I can do, the A to D board is working but the encoder board is not working, and they are so old that I cant find any used replacements. When I turn it on, all the axes run to their limits... so conversion it is!
Time to create page: 0.372 seconds
