DynaMite 2800 retrofit.
4 years 2 months ago #249244 by Birdman3131
Replied by Birdman3131 on topic DynaMite 2800 retrofit.
So success has been made. Started trying to figure out what was going on out of the 48 volt power supply I was only getting about 10 volts or so maybe 15 I forget. So I figured that the supply was the problem. removed the power supply went and grabbed a RD6018 I have and set it to 48 volts 7 amps as the original supply is speced to. Well as soon as I turned on the rd6018 it instantly pegged at 7 amps which is a problem. After some experimentation and tracing I found a wire that if I removed got rid of said 7a short. Turns out the y-axis stepper motor driver was bad. Removed it from the equation and everything works swapped x and y and y drive works so it's definitely the driver.
There was a spare stepper driver that came with it it's not shorted but it also does not appear to work.
Now that I have it somewhat functioning I need to see if I can either repair one of these stepper drivers or buy a different one. Spindle drive did work I didn't take it up very fast though.
Time to create page: 0.062 seconds
