Why and how do you get random E-STOPs? I supposed the machine stopped because it thought an axis "jumped" outside of machine limits, but that seems not to be the case. If you have electrical issues with ESTOP triggering via noise, fix that first. E-STOP usually is a loop of "N"ormally "C"losed switches that open when actuated. This way broken or faulty ESTOP chain won't let you activate the machine. Hard to imagine you can influence that with induced noise?As I get random estops when the spindle runs I suspect I am getting noise on the 10v signal lines as well as my inputs. Would the following scenarios be possible:
- Issue with the 24v power supply generating noise as a result of noise on the AC line due to spindle drive?
- My 0-10v analog signals wires are just single core cables I twisted as pairs (see wires labeled ER(R)1, ER(R)2, etc in first post), despite the short run, could noise be introduced on them and am I better off swapping to shielded twisted cable? This wouldnt explain random estops as those would have to be from noise on inputs.
Also must be shielded, but if this was the issue, the machine would jump a lot, so i do not think this is a problem for now.- My 0-10v analog signals wires are just single core cables I twisted as pairs (see wires labeled ER(R)1, ER(R)2, etc in first post), despite the short run, could noise be introduced on them and am I better off swapping to shielded twisted cable?
This for sure means something is very wrong with grounding/shielding on the wiring.As I get random estops when the spindle runs I suspect I am getting noise on the 10v signal lines as well as my inputs.
Generally through noise on a limit switch input.
But that is not a general "E-Stop", linuxcnc complains "axis limit exceeded" or something like that.
I generally debounce the limit switches, as nuisance tripping can be expensive, whereas a 10ms delay in tripping the limit switches probably doesn't matter that much.
