Help with the big picture
2 years 9 months ago #290129 by sliptonic
Replied by sliptonic on topic Help with the big picture
DMM has been unable to resolve the issue. I don't want to run step/dir. So I've returned the DMM stuff and will be buying something different.
@pcw, What hardware would you recommend for maximum compatibility with my 5i25/7i77 control? I'm willing to throw a bit more money at this to minimize the F*ck-around-factor.
2 years 9 months ago - 2 years 9 months ago #290234 by BerTiN
Replied by BerTiN on topic Help with the big picture
PCW post=282030 userid=481
For step/ dir, the default setup and timing should work though you
obviously need a different daughtercard
7i77 can't handle step/dir to drive a servo's driver ?
Last edit: 2 years 9 months ago by BerTiN.
2 years 9 months ago #290236 by tommylight
7i77 can drive velocity mode servos, those are +-10V input drives, also known as analog drives.
If you already have 5i25/7i77 you can get a 7i85S (there are 7i85 and 7i85S, one is step/dir the other is SSerial, do check that) and can be used to drive any stpper/servo drive in position mode with step/dir signals.
The following user(s) said Thank You: BerTiN
2 years 9 months ago #290439 by BerTiN
Thanks for precisions, Tommylight. While this time, I had a look to these two ways of driving servos.
Finally, most of people use 7i77 for this kind of retrofit, and the step/dir way is not really more attractive than the analog way, specially if you work in a closed-loop way with encoders. Maybe the PID-Tuning could be a little bit touchy.
I'll go the analog way, so. ;)
2 years 9 months ago #290444 by tommylight
It does not matter if you use analog or step/dir with LinuxCNC, granted you close the loop in LinuxCNC, everything works perfectly.
Step/dir is easier to setup and tune with less chances of "run away" or mishaps.
2 years 6 months ago - 2 years 6 months ago #298887 by vre
Replied by vre on topic Help with the big picture
If you are using the 7i77 then you pretty much have to use analogie voltage control.
Position control with analogue voltage is a terrible idea, so not that.
Torque control and Speed control can both work, but speed control is likely to be much easier to tune.
I was recently introduced to a very simple and effective way to control an axis under speed control.
Set up the PID for position control, in the usual way.
Connect pid.N.command-deriv to joint.N.vel-cmd
Set P I and D to zero, and adjust the pid.N.FF1 value until the axis speed and commanded speed match exactly.
Then you should find that all you need is a very small amount of P gain to bring things under control.
Is this method a better alternative from classic method?
(increase P until oscillation then reduce P to 70% then eliminate cruise ferror with FF1 and fix start-stop error with little FF2)
Can you give an example for a hal file generated by pncconf ?
Last edit: 2 years 6 months ago by vre.
Time to create page: 0.346 seconds
