Possible retrofit of a Körner Magic550 CNC Machine
1 year 7 months ago #325136 by tommylight
Do the motors have tachos on them and what voltage do they output?
Encoder incremental 1Vss does not seem right, should be TTL level normally so 5V or more.
1Vss is ok for resolvers although they can do more...
Scour ebay.de for Kolmorgen, those can be found for good prices although last i looked was probably two years ago.
But you do need to have the above info correct before jumping in.
1 year 7 months ago #325147 by Dedeer
The servos don’t have tacos .The encoder is the ERN1387 which is listet as an incremental encoder in the data sheet with the “schnittstelle” being 1Vss. It does say ,in the data sheet,that it needs 5V . As I understand these encoders give an analog sinus-cosines signal which then gets  converted  by the driver electronics to digital signal.
1 year 7 months ago #325163 by GA1991
We've recently suffered a problem on our DMG CTX 310, with an error on the HSCI bus. Had to change the PLC I/O board, which is not cheap.
Finding a generic drive for those servos might be a problem. If I were you I'd toss the Heidenhain stuff, make some servo motor mounting adapters and just get new servo+drive sets.
I worked on a project with some Leadshine EL7-EC servos and drives through EtherCAT (although not with LinuxCNC, but they could easily be integrated) and can recommend them. Very smooth motion, quick integration and easy tuning. I also used a Mesa 5i25 + 7i76 on another project and the Leadshine EL6/EL7-RS should work just as fine through Step/Dir.
Motors are compatible with both series (23-bit encoder). Big pluses of EL7-EC vs. EL6/EL7-RS is (to me) STO. Both series are relatively inexpensive.
1 year 7 months ago #325257 by Dedeer
 Leadshine was one of the manufacturers we had in mind and we asked one of the distributors for a quote . They recommended the 130mm flange range but we have no space in the machine to mount these motors so we asked them for a quote for the 100mm flange and they said that these servos are not that good and that in May they are releasing a new improved version .
Meanwhile i found this italian company called MotorPowerCompany which would have the fitting servos for our machine .Anyone has or had any experince with them?
1 year 7 months ago #325402 by Dedeer
Today i took some pictures of the machine . This is a small machine with a footprint of 120cm x140cm x 170cm but weighs a whooping 4000Kg. Its made from epoxy granit of some sort. The last picture is how the machine used to look ,it´s the only picture i found online.
1 year 7 months ago #325465 by Dedeer
More photos ,this time the Heidenhain servos and the Creativtec.drives.
Time to create page: 0.324 seconds
