Amada turret punch
  • robh
  • Topic Author
  • Premium Member
  • Premium Member
2 months 1 week ago #349092 by robh
Amada turret punch was created by robh
hi
has any one done a amada turret punch?
i have a amada Vipros587 Queen punch with C axis on punch stations
also is pure hydrulic on its punch unit
the machine its self would be easy, i am wondering if any one has solved the control of the hydrulic ram on the punch stations? for replacing the dedicated PHNC System
yes some custom punch cycles would be needed for slotting and profiling etc
2 months 1 week ago #349111 by tommylight
Replied by tommylight on topic Amada turret punch
Not sure it was an Amada, but i am sure there are turret punches with LinuxCNC, there are some short videos on youtube.
We can try to help for sure, just try to divide challenges in small chunks
Thing is, one of the forum members that did some of them will not help anyone, ever, but he will gladly ask for help here very often.
  • robh
  • Topic Author
  • Premium Member
  • Premium Member
2 months 6 days ago #349143 by robh
Replied by robh on topic Amada turret punch
Hi tom
90% of machine is no brainer done many limuxcnc before check out my posts in build section from years back , and YouTube
Only I was interested know how someone solved the punch hydraulic part , but if machine is servo or fly wheel driven then punch part is easy
Current control has a full on control with a special hydraulic servo controller for punch ram , and id like to replace it as very old now
I'll post some photos up next time I am at the machine
  • robh
  • Topic Author
  • Premium Member
  • Premium Member
2 months 6 days ago #349145 by robh
Ok seems Yuken LSV Series servo valves are most common used
And can be +/-10v in or 4-20ma commands
Seems run at 450hz so would require a fast loop than 1khz I would think to get smooth motion
Rest of the phnc just set stroke length as set sheet thickness on it and other things too so ram only retracts for needed stroke giving you faster punch rate
The hit rate on the machine I'm.doimg is 520 I believe , king version is 1200 hits on a nibble rate this is
1" spec not sure will check spec sheet
So this does not seem that hard to interface to
Time to create page: 0.079 seconds
