Solidcam to EMC2 post processor
13 years 3 months ago - 13 years 3 months ago #37074 by hardware_crash
The variables were renamed in the new versions till 2011 .
mist_coolant was renamed to mach_mist_coolant
flood_collant was renamed to mach_flood_coolant
and so on ..
Last edit: 13 years 3 months ago by hardware_crash.
13 years 2 months ago #38088 by spangledboy
The LINUXCNC.GPP post processor file works well in SolidCAM 2013 for me.
However, be aware that the G43 command has been commented out in it, so G code created with this will not carry out tool length compensation. If you don't carry out any tool changes in a given job you won't notice, but when you do change to a tool with a different length you may well suffer a tool crash as I did yesterday.
It serves me right for not checking my code properly before running it, but just a word of warning for others who may want to use this file.
The relevant lines are numbers 399 & 400 as shown below:
;gcode = 43
;{nb, 'G'gcode, ' H'tool_number, ' D'(tool_number+30), ' '}
Remove the leading ; to re-enable the lines. I also think that the D parameter is not supported in G43 for LinuxCNC, so I removed that part from the second line.
Ben
12 years 6 months ago #45819 by jtc
Replied by jtc on topic Solidcam to EMC2 post processor
I'm testing this post processor on SolidWorks2014. I can use in milling operations, and linuxcnc accept the code (simulation only for now). But for the turning version, I can't find the machine FANUC0T, so I'm wondering if I need the FANUC0T.VMID file to be able to select the machine.
João
12 years 1 month ago - 12 years 1 month ago #50615 by library
I found the post processor by Robo Dan and other forum members to be very useful for starting out. Along the way as I've added parts to my G0704 mill I have modified it to support these things:
  • Auto Z touch off plate code from OrangeCat (calls M600 at beginning of file and intercepts M6 T# calls to measure each tool)
  • G33.1 rigid tapping support (must have mill setup to do rigid tapping).
  • Clearer naming. Instead of Fanuc5a the controller is called LinuxCNC.
  • Prints out a list of all the tools used in the job at the top of the gcode output including their descriptive names.
  • Uses LinuxCNC DEBUG command to print out the tool needed at each tool change.
  • Outputs gcode files with .ngc extension instead of .tap
  • General cleanup of the commented out code
  • Increased precision for all coordinates. Helps with TPI during tapping
  • Tool Length offset (Gcode 43) is commented out on lines 372 for the version without auto touch off. If you change tools or use the TLO table in linuxcnc you'll probably want to uncomment it
CAVEATS
I have not tested everything possible. Specifically I have not done any 4th axis stuff or any tool compensation. The way I use Solidcam is to select all the operations in a setup and generate a single gcode file for these. As long as it simulates right in Solidcam, linuxcnc will work the exact same way. I have tested nothing with changing planes or multiple setups in one file (ie MAC 1, MAC 2 in same file). I create a new file for each machining position since I need to take the part out of the vise, change it around and re-zero anyway.
If you use the auto z touch off version make sure you clear the TLO before *each* job (ie hitting start). I have a button to clear the TLO using pyvcp and an led that shows me if the TLO is currently set.
I have also not touched nor added the lathe controller. I will be looking at that in the next 6 months as I get my lathe converted to a simple 2 axis lathe.
INSTALLATION
Unzip the zip file and copy all 4 of the files to your Gpptool directory. Use windows search if you don't know where the Solidcam Gpptool directory is. Decide whether you want to run the auto z touch off version or not and then rename the version you want to use to LINUXCNC.GPP. Afterwards fire up SolidCam and LinuxCNC will appear in your list of controllers.
Unless you have an auto z touch off plate and have remapped M600 and M6 in linuxcnc you really don't want to run the auto touch off version.
BUGS
I know of only one strange situation with the auto touch off version. If you abort in the middle of the job and then want to restart on a certain line the Auto Z touch off measuring doesn't work properly. The proper procedure is to clear the current tool length offset, use the MDI to issue M600, Start the program again (I usually start right at a tool change). Practice, or watch the Z height closely or you will bury a tool in the work piece.
YMMV, not responsible if you destroy your machine or it kills your dog.
File Name: LinuxCNC-S...ssor.zip
File Size:10.98 KB
Last edit: 12 years 1 month ago by library. Reason: added disclaimer
The following user(s) said Thank You: spangledboy, rokag3
12 years 1 month ago #50621 by cncbasher
thanks for your post , i'll take a look
11 years 11 months ago #53168 by pippin88
I'm having a problem with Solidcam 2014 gcode generation for my lathe.
I use a friend's seat and have cobbled together my own post processor for a LinuxCNC lathe (I don't have access to a reseller post because I'm just using his seat).
I'm making a poly-v belt pulley.
Solidworks 2014
Solidcam 2014
When I try to run the code to profile the pulley grooves, I get an error in LinuxCNC: "Current point same as end point of arc"
It points to this code:
G1 X75. G3 X74.2062 Z-3.4819 R0.6032 G1 X71.964 Z-3.89 X73.84 Z-4.231 G3 X73.84 Z-5.8887 R0.88185 [B](this line errors)[/B] G1 X71.964 Z-6.23 X73.84 Z-6.571 G3 X73.84 Z-8.2287 R0.88185[B] (this line errors)[/B] G1 X71.964 Z-8.57 X73.84 Z-8.911 G3 X73.84 Z-10.5687 R0.88185 [B](this line errors)[/B] G1 X71.964 Z-10.91 X74.206 Z-11.318 G3 X75. Z-11.8849 R0.6032 G1 X75.486 G0 X87. Z3. M30 %
GWizard editor gives the following:
Line 593: G3 X73.84 Z-5.8887 R0.88185 G3: Counter-clockwise circular interpolation (move in a circular arc at feed speed) Relative IJK resolves to absolute IJK = I73.84 J0 K-4.231 (R)adius = 0.88185 Helical interpolation along Z-axis. Helix depth = -1.6 Arc endpoint: 73.8400, 0.0000, -5.8887 Arc center coordinates: 73.8400, 1.7637, -4.2310, radius = 2.4205 (determined by R) Arc angles: 270.0 to 270.0(.0 degrees total) Helix pitch in program units = .0 Time: 40:50.5 Adj Time: 40:52.9 V End: 50 [B]ERROR: Current location is the same as the end location for this arc. [/B]
I've worked out I can avoid the error if I don't do a finish operation - I rough and then do a semi-finish (iso turning), leaving only 0.01mm, and the code runs fine.
I've tried finish with stair turning and iso turning - both produce this error.
Attached are:
Image of faulty toolpath (in GWizardE)
Image of working file with 0.01 offset semi-finish toolpath (in GWizardE)
Image of toolpath in Solidcam
.gpp file
.prp file
Full gcode problem file
Full gcode working file with 0.01 offset semi-finish
Help is much appreciated
I spent all day today trying to find a solution to this! I've googled and looked at other posts, and the post (.gpp) manual, but I can't claim to understand a lot of it.
Time to create page: 0.363 seconds
