# The following items are free,
# DXF2GCODE Cam software
# Open Terminal, copy and paste the each line one at time into Terminal, press enter after each paste.
cd ~
git clone
git.code.sf.net/p/dxf2gcode/sourcecode
dxf2gcode-sourcecode
cd /home/`whoami`/dxf2gcode-sourcecode/source/
sudo chmod +x /home/`who | cut -d' ' -f1 | sort | uniq`/dxf2gcode-sourcecode/source/dxf2gcode.py
# To run Dxf2gode Cam Software
# Copy and paste the following into Terminal
python /home/`whoami`/dxf2gcode-sourcecode/source/dxf2gcode.py
# To install Sketchup 8 on Ubuntu, Mint or Debian.
# First install Playonlinux on Ubuntu or Mint use the Software install manager for your distro.
# For Debian
# this link for Wheezy
packages.debian.org/wheezy/playonlinux
# After install of Playonlinux choose install program from within Playonlinux
# then use search function within Playonlinux for google sketchup. Once found choose to install google sketchup. Playonlinux
# will download and install it for you.
# Choose a exe file to start the program, (it will be listed). Icon will be placed on
# your desktop. Program works flawlessly.
# To get Sketch-U-Cam, (CAM add-on) goto web site
www.openbuilds.com/resources/sketchucam.1/
sign up for login, it is free then download
# Open Sketchup choose menu item Window->Preferences->Extentions->Install Extention
# Choose the Sketch-U-Cam file from the folder you downloaded it to.
# After install of Sketch-U-Cam remember to goto menu item
# Tools-->Phlatboyz-->Options-->Misc Options
# For the line labeled
# Use_compatiable_dialogs set TRUE if you cannot see the parameters dialog
# to TRUE
# CamMill Cam software
# Goto web site
www.openbuilds.com/resources/cammill-for-windows-linux-mac.149/
# Sign up for login, it is free then download Manual which contains web link to Wiki for install
# Simple GCODE generators Wiki
wiki.linuxcnc.org/cgi-bin/wiki.pl?Simple...NC_G-Code_Generators
# 1. Drilling Speeds-n-Feeds
# 2. Arc Generator
# 3. Facing Software
# 4. Bolt Circle Array Software
# 5. Counterbore Software
# 6. Grill Drilling Software
# 7. Bezel Engraving Software
# 8. Text Engraving Software
# 9. Multi-line Text Engraving Software
# 10. Pycam - Drop Cutter Surfacing Software
# 11. Dxf2gcode - import a 2D DXF file and produce G-code
# 12. Rectangular-Circular Pocketing Generator
# 13. Grid Rectangular Circular SpiderNet G-code Generator
# 14. Airfoil G-code Generator 3-4Axis XY-XYUV Foam cuttting (DEAD Link for this one) try this instead
swarfer.co.za/rc/wire/index.php
# 15. Other G Code Generators
# 16. Using Python scripts with Axis
# 17. Using Python scripts with Windows
# 18. Using Python scripts online
# 19. mGcodeGenerator
# 20. OpenVoronoi and OpenCAMLib
# As for pay for software I have DesignCad v22 with ContourCam Add-on but have not used it yet was very reasonably priced for both pieces of software
