- Thank you received: 37
Yes, in fact I used it last night. I have a postprocessor for LinuxCNC lathe but can't remember where it came from. Nor do I know if the standard LinuxCNC postprocessor now works properly (it is quite likely that it does)Vitran wrote: Has anyone have any luck with Fusion 360 CAM for lathe work?
It can be, but only for non-profit or startup companies.Is it free for use?
Vitran wrote: Has anyone have any luck with Fusion 360 CAM for lathe work? Is it free for use?
