Merging operations NGC files Fusion 360
  • npostma
  • npostma's Avatar Topic Author
  • Junior Member
  • Junior Member
01 Jun 2025 10:40 - 02 Jun 2025 08:56 #329503 by npostma
Hi community,
Thanks to the help of several members, I’ve been able to upgrade my machine and it’s now working better than ever. So I wanted to give something back.
I mainly use Fusion 360 to create my toolpaths, but I noticed I couldn’t easily use multiple tools within a single G-code file. Fusion360 requires saving each operation as a separate .ngc file. To streamline my workflow, I wrote a small Python script that merges all the generated .ngc files back into one file.
To be clear: I’m still quite inexperienced with CNC (this is just a hobby for me), but I am a software developer—so any feedback or improvements are very welcome! I’m still testing and iterating, but maybe it’s already useful for some of you.
You can find the project here:
github.com/npostma/GSeam/
Last edit: 02 Jun 2025 08:56 by npostma.
01 Jun 2025 13:01 #329508 by kworm
Replied by kworm on topic Merging operations
Hi npostma,
There shouldn't be any issue using multiple tools in a single g-code file in Fusion360. You create your setup and then separate operations under the setup. Each operation can use a different tool. Just make sure the setup is selected when you post and it will put all the operations in the same file. If you just have a single operation selected then it will just output that single operation in the g-code file.
  • npostma
  • Junior Member
  • Junior Member
01 Jun 2025 15:14 - 01 Jun 2025 15:59 #329514 by npostma
Replied by npostma on topic Merging operations
I’m guessing you’re using Fusion 360 with a paid license? I’m just a hobbyist and only use the free version (not for commercial work), which is much more limited. When I try to export multiple operations with different tools at once, Fusion 360 warns me that this isn’t possible in the free version—I have to save each operation as a separate file as suggested by fusion360. So, for LinuxCNC/Fusion360 users like me, the options are either to load each file separately in LinuxCNC (after each one ends), or to merge all files into a single program, which is what I do with my own script.
Even as a hobbyist, I often need toolchanges: most of my projects require a roughing pass with a large end mill and then finishing with a smaller tool.
Question:
Does anyone know if it’s possible to display a popup or notification when running an M0 or M1 g-code in the AXIS GUI? I’d like to give myself (or any user of my script) a clear notification to change tools, especially since when remapping M6 I lose the standard toolchange popup.
Thanks!
Last edit: 01 Jun 2025 15:59 by npostma.
01 Jun 2025 18:00 #329524 by kworm
You are correct I have a paid license. I used to use the free version some time ago and I don't remember it having that limitation but I know they have made multiple license changes over time for the free version which is unfortunate. Glad to see you have made a solution to work around it.
I don't use axis but this post may be similar to what you are looking for:
forum.linuxcnc.org/20-g-code/36186-use-m...messages-my-solution
Time to create page: 0.719 seconds
