Linux equivalent to NCPlot
- metasim
17 Dec 2010 19:44 #6103
by metasim
Linux equivalent to NCPlot was created by metasim
Is there anything similar to the windows commercial program NCPlot where you can edit gcode directly AND have a backplot/toolpath visualization synchronized with it. I'm thinking of something along the lines of combining gedit with the backplot display in Axis. I can't find anything quite like NCPlot, but thought I'd ask to make sure I'm not missing something obvious. I know you could switch back and forth between gedit and axis (with the refresh button), but I'm interested in something even more tightly coupled that doesn't have any of the machine control parts.
Thanks,
metasim
Thanks,
metasim
- psha
- User is blocked
17 Dec 2010 20:21 #6104
by psha
Replied by psha on topic Re:Linux equivalent to NCPlot
Take textview widget, Gremlin widget and place two buttons to save/load file
But you steel need running EMC -- backplot is created somewhere inside
- Dan Falck
- Visitor
17 Dec 2010 22:01 #6107
by Dan Falck
Replied by Dan Falck on topic Re:Linux equivalent to NCPlot
You can probably work something out with the gedit plugins and gedit 'external tools'. I did this a couple years ago with the axis sim and python connecting it. Sorry, I lost a lot of that a couple computers ago, but there is something along the lines of Jeff Epler's jdi.py ('just do it') that lets you connect directly to axis with python.
Using that, you can have gedit (through some python scripting) open axis (if it's not already open), unconnect estop, turn on the machine, and start your program. I believe I had to do some trickery with the homing in the ini (make not worry about homing).
It is pretty sweet, once you do have it set up.
Here is how I started out:
wiki.linuxcnc.org/cgi-bin/emcinfo.pl?Usi...id_In_Creating_Gcode
If I get some time, I will see if I can recreate some of that.
Dan
Dan
- metasim
17 Dec 2010 22:31 #6109
by metasim
Replied by metasim on topic Re:Linux equivalent to NCPlot
Wow gents, that's good info; I'd perused the source but missed the "gremlin" directory.... I looks like the bits and pieces are all there to do what I want, just might require some refactoring if I wanted to keep it from depending on the emc/hal subsystem.
The underlying drive behind this is that I'd like to do the CAD/CAM part on MacOS as that's my day-to-day computer (the CNC computer is the standard EMC/Ubuntu disto). I'm part way through getting EMC to compile in simulator mode, just to get Axis running, but there's a bunch of Linux specific/non-POSIX calls and constants that require tweaking, so it's been a ongoing project. Knowing about gremlin helps focus on the bits that matter in this use case. The gedit plugin page is very helpful too.
Thanks for the help.
metasim
metasim
- Dan Falck
- Visitor
17 Dec 2010 23:03 #6110
by Dan Falck
I was digging around on my backup drive and found this bit that shows what you can do with a linux box with axis/sim on it:
dan@dan-desktop:~/emc_trunk122408/scripts$ python
Python 2.5.2 (r252:60911, Jul 31 2008, 17:28:52)
[GCC 4.2.3 (Ubuntu 4.2.3-2ubuntu7)] on linux2
Type "help", "copyright", "credits" or "license" for more information.
>>> import emc
>>> s =emc.stat()
>>> s.poll()
>>> s.position
(0.19685039370078738, 0.1968503937007875, 0.5, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0)
>>> s.origin
(0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0)
so now you're hooked in to the stats on emc
>>> c=emc.command()
>>> c.state(emc.STATE_OFF)
>>> c.state(emc.STATE_ON)
now you can command it to do stuff
since I had axis open with it's standard 'axis.ngc' program (the one that show's 'EMC2 AXIS' on the screen), I was then able to get the machine running:
>>> c.mode(2)
>>> c.auto(emc.AUTO_RUN,1)
>>> import emc
>>> s =emc.stat()
>>> s.poll()
>>> s.position
>>> s.origin
>>> c=emc.command()
>>> c.mode(2)
18 Dec 2010 00:01 #6114
Replied by andypugh on topic Re:Linux equivalent to NCPlot
metasim wrote:
FWIW I have compiled HeeksCAD for MacOS. I haven't even tried it with Axis/EMC2.
I am currently passing my time developing hardware drivers for EMC2 using Xcode as my IDE, so you are not the only Mac fanboi in EMC land.
- metasim
18 Dec 2010 17:11 #6141
by metasim
There was definitely some sheepishness in that confession of mine.
I probably have more years of Linux experience under my belt than MacOS, but with age one gets more enamored with the pampering of the likes of MacOS X. I rationalize it knowing I can always get a bash terminal. That still counts, right?
One are that can be miserable is dealing with Python on MacOS X. The Apple provided default install is always behind and broken, yet getting it from macports invariably ends up in some compile error or PYTHONPATH inconsistency. It would be really nice to be able to get enough of EMC compiled to be able to run a script like Dan's, connecting remotely to the Linux EMC host.
metasim
metasim
- trojansf
23 Oct 2024 20:12 #313001
by trojansf
Replied by trojansf on topic Re:Linux equivalent to NCPlot
You probably want to check out CNC Macro Simulator II.
It's device agnostic and only requires a browser to run. I use it on my mac all the time.
It's definitely worth it. The developer is responsive and has made successive suggested changes to the software.
kandksoftware.github.io/macro-terminal-pro/en/
- meister
- Thank you received: 502
24 Oct 2024 08:05 - 24 Oct 2024 08:06 #313039
by meister
Replied by meister on topic Re:Linux equivalent to NCPlot
how many people want something like this?
i could build a small pyqt-gui that generates a small gcode preview using the 'rs274' tool.
but i already have a console tool that converts gcode to svg.
github.com/multigcs/riocore/blob/main/riocore/files/ngc2svg.py
Last edit: 24 Oct 2024 08:06 by meister.
- meister
24 Oct 2024 08:09 #313040
by meister
Moderators: Dan Falck
Time to create page: 0.297 seconds
