Error in documentation, several minor additions
  • Topic Author
  • Moderator
  • Moderator
2 years 3 months ago #306200 by tommylight
linuxcnc.org/docs/master/html/code/building-linuxcnc.html
Until section 4.2 the working directory is "linuxcnc-source-dir" and that is a nice change, but from then on it refers to the old naming "linuxcnc-dev" in the copy/paste parts.
docs.google.com/document/d/1jeV_4VKzVmOI...ading=h.9yat9yuit8mp
If refers to using Geany that is not included with BookWorm, but it is with our version, so would not hurt to mention that if geany can not be found to install it with sudo apt install geany.
Same document a bit lower, add --show to latency histogram, it shows the excursions outside of the visible boundaries that are always, always ignored when checking latency as they are represented with very thin colored lines at the very edges of the graphs, so
latency-histogram --nobase --sbins 1000 --show
2 years 3 months ago #306224 by andypugh
Can you create an issue for these so that they don't get lost?
github.com/LinuxCNC/linuxcnc/issues
  • Topic Author
  • Moderator
  • Moderator
2 years 3 months ago #306233 by tommylight
Replied by tommylight on topic Error in documentation, several minor additions
I do not have an account there, maybe i can convince myself to open one.
2 years 3 months ago #306252 by andypugh
I think you should :-)
2 years 3 months ago #306256 by rodw
Moderators: HansU
Time to create page: 0.065 seconds
