- Thank you received: 784
wizard69 wrote: it has been awhile since I've posted but here is my take on control panel technology based on years working automation.
One - touch screens either suck or are the best thing since slice bread. Engineers have a tendency to throw everything on the touch screen leading to a problematic user interface.
As for custom keyboards like this they also have their good points and bad points. If you can write your own interface software or at least have open source software available there are far fewer bad points. After that the remaining problem is the hard nature of the button functions, such a keyboard is great as long as the key legends match up with your needs.
Often the best avenue is to make use of a standard PC keyboard combined with selective use of industrial push buttons and selectors. The keyboard for easy text entry and push buttons for frequently used functions. Use hard switches for cycle start / stop, emergency stop (this is a given), coolant and air blow off controls, vacuum control and others depending upon your machines use case. Some may see this as old fashion and frankly it does depend upon usage, if you are running a lot of quick cycles it makes more sense to have a cycle start push button than if you machine cycles last for hours for example. In the end it is hard to beat physical switches for certain needs from the users standpoint.
In the end there are no absolutes and I can't comment on personal usage for that keyboard.
