Start LinuxCNC in a script
8 years 5 months ago #111097 by Cpk_Rbt
I'm trying to launch LinuxCNC when my computer boots, by way of a bash script.
INI DISPLAY = linuxcncrsh
classicladder is launched --nogui
I'm still getting an error that there either:
is no $DISPLAY environment variable
or, if I
export DISPLAY=:0.0
, couldn't connect to display ":0.0"
Anyone have any ideas for how to accomplish this?
8 years 5 months ago #111098 by Grotius
Replied by Grotius on topic Start LinuxCNC in a script
If you install linux from cd i think it will work with standard bash script.
Try also ini display = axis
If booting up and showing ladder you are at the right way !
If you cloned linux from source i think you have to add several scripts to your bash file like in the script folder :
. ./rip-environment
linuxcnc
So at this moment it can be several things.
In beginning you can load classicladder in hal section. i see.
Buy in your ini section maybe delete display section. That can also make difference.
To only load classicladder is possible, you need some time to investegate.
8 years 5 months ago #111117 by Cpk_Rbt
Replied by Cpk_Rbt on topic Start LinuxCNC in a script
I foolishly thought that I could test via SSH and it would be the same, I was wrong. When launching in a script while sitting in front of the PC, it works fine.
8 years 5 months ago #111265 by andypugh
Replied by andypugh on topic Start LinuxCNC in a script
Cpk_Rbt wrote: I foolishly thought that I could test via SSH and it would be the same, I was wrong.
ssh -Y
Tends to work, just for future reference.
The following user(s) said Thank You: Cpk_Rbt
8 years 5 months ago #111286 by Thom
Replied by Thom on topic Start LinuxCNC in a script
Check this out
forum.linuxcnc.org/9-installing-linuxcnc...4-autostart-linuxcnc
It starts not by script, but it is much easyer
Regards,
Thom
8 years 5 months ago #111315 by Cpk_Rbt
That's a handy tip! Thanks for sharing.
Time to create page: 0.242 seconds
