Chinacnczone verticle mill with ZK Motion controller and latest MPG WHB04 6 axis
6 years 9 months ago - 6 years 9 months ago #154836 by AP3
Greetings,
I searched each phrase in my title and did not find much....
The Machine seems decent and when I have it running, I think it will meet my needs.
Here we go.
1) I am told that Chinacnczone (CCZ) and ZK Motion have pirated Mach3 software and I need a license from Mach3
2) I loaded Ubuntu on a designated computer and am told Mach3 will not run on Linux
3) It appears (I may be wrong) that Linuxcnc will not run the ZK Motion controller or the MPG
Do I
A) just buy Mach3 and be done with it?
B) Find a way to run this on Linuxcnc
1) New controller?
2) New MPG
Win8 64
Intel J1900
500GB SSD
8GB RAM
AP3
Last edit: 6 years 9 months ago by AP3. Reason: spelling
6 years 9 months ago #154838 by tommylight
Oh good, not spam! :)
My advice, get rid of whatever and make it work with Linuxcnc. Seen plenty of horror with Mach3 and co to insist vigorously on avoiding it altogether.
6 years 9 months ago #154844 by AP3
What should I replace it with? 6 axis control and pendant??
AP3
6 years 9 months ago #154859 by tommylight
From parallel port wired directly to drives, to Mesa boards. I use parallel for small machines and Mesa for big ones, even on some retrofitted industrial ones weighing in at over 5 tons.
6 years 9 months ago #154865 by AP3
Thanks for your thought and quick response. I am certainly on a learning curve.
6 years 9 months ago #154872 by andypugh
The nearest equivalent of the ZK motion controller for a LinuxCNC installation is probably the Mesa 7i96
store.mesanet.com/index.php?route=produc...t_id=311&search=7i96
But that isn't supported by the normal PnCConf wizard as far as I know. (there is a standalone setup tool)
For more IO and a spindle controller there is the 7i76E.
Those both connect by Ethernet.
If you have a PCI or PCIe port then 5i25 / 6i25 + 7i76 has been popular for many years and is very well supported.
It should be possible to use the MPG, there is another thread about that particular one o n this forum.
Time to create page: 0.239 seconds
