Nachrüstung CNC
5 years 9 months ago #194240 by thomas.heisig
Retrofit CNC was created by thomas.heisig
Halo
although I have already posted in this forum I would like to introduce myself, and immediately afterwards burden you with a problem.
My name is Thomas and will work as stonemaze in My own company and also have an German electrical engineer education .
I have already implemented a 3 axis saw with UCCNC and an ETH300 in my company which works fine with 2-fold closed loopsystem .
My new project is a retrofit of a 4+1 axle machining center (which is a real heavyweight with a total weight of 10 tons).
The axes 3 phases 500V 2.2 KW are controlled via regular VFD closed loop over PWM or clock/direction, the path encoder is to be queried via a MESA 7i95
The plan was to take a Raspberry Pi 4 Model B with 4 GB as an HMI / controller on which I have now installed Linux Debian Buster RT with LinuxCNC 2.9.0 becuse it is more flexible and give the chance zu use RT Encoder
Machine configuration
Controller - Raspberry Pi 4 Model B 4GB and USB 3.0 SSD 32GB, 32GB SDHC Disk
Software Controller - Linux Debian Buster RT with LinuxCNC 2.9.
Software CAM - W10 with Solidworks (postprocessor still unknown)
Axes every 2.2 KW VFD with PWM / clock direction and encoder 2500 increments ABZ and TTL data
wayencoder TTL-Data / ABZ DN (Siemens)
Dimensions travel distances - working range 2000 * 3000 * 500, 360 O mm limits 2200 * 4000 mm
Spindle Modbus Controled
IO PLC - S7400U 64 inputs and outputs
The following problems occurred during the planning!
- Installation of Probe Basic failed (already requested in this forum)
- Mesa 7i95 is not in the list of PNCCONF
- Establishing a Modbus connection to the PLC to evaluate the I/O
i will be very pleased if these forum wil give me support to get these thin running.
thanks
Thomas
5 years 9 months ago #194252 by PCW
Replied by PCW on topic Retrofit CNC
The 7I95 is not supported by pncconf yet but you can use a pncconf
configuration created for a 7i96 and hand edit it to work with the 7I95
Things that need changing:
Change the card name in the ini file to "7i95" ( using the "Use INI substitution for Mesa board names" option)
Change the inputs from GPIO to INMUX
that is change:
gpio.000.in
to
inmux.00.input-00
etc
5 years 9 months ago - 5 years 9 months ago #194269 by thomas.heisig
Replied by thomas.heisig on topic Nachrüstung CNC
hi,
thanks for your suport :)
the first act is done and LinuxCNC starts with gmoccapy.
the next step (Tomorow) is to rewrite the .ini file to correct the Gpio to Inmux like shown on Mesaflash --device 795 ....
I think tomorrow I can assemble the machine.
PS : Don't think I'm a grammatical spastic, but I'm not familiar with writing in foreign languages, sorry for that.
Last edit: 5 years 9 months ago by thomas.heisig.
5 years 9 months ago #194354 by thomas.heisig
hi,
I´m using - mesaflash --device 7i95 --readhmid - for readout.
there are only 3 encoders for m,uxedQCount (0 1 2) 57 ports at all
the next is an error Parameter or pin ´hm2_7i95.watchdog.timout_ns´not found
5 years 9 months ago #194356 by PCW
Replied by PCW on topic Nachrüstung CNC
The 7I95 has 6 encoders (using multiplexed inputs these 18 signals are reduce 10 to FPGA pins)
"the next is an error Parameter or pin ´hm2_7i95.watchdog.timout_ns´not found"
This is likely a typo or editing issue or the driver failed to load for some reason
Once you get LinuxCNC to start with the 7I95, you can list all available pins with:
halcmd show all hm2
5 years 9 months ago #194359 by thomas.heisig
ok, i get LinuxCNC running after setup new on PCNconf as 3 Axis.
(at this time i study the HAL tutorial , a little bit dry but .... )
where is it posible to change gpio to Inmux ?
i havent found it in the mashine .hal or . ini
Time to create page: 0.097 seconds
