'module' object has no attribute 'get_value'
5 years 6 months ago #205429 by elisa
Hi to all,
I have a problem wiht the command "hal.get_value", when I run the python script I get this error:
in <module> x= hal.get_value("x-pos-fb")
AttributeError: 'module' object has no attribute 'get_value'
Please write soon!
5 years 6 months ago #205484 by andypugh
I thought you reported that this was fixed?
5 years 6 months ago #205504 by cmorley
can you post all the code you used?
There are other commands that need to be called before that works.
5 years 6 months ago #205508 by elisa
There are my python code and the postgui hal.
File Name: postgui.hal
File Size:127 B
File Name: my_arduino_2.py
File Size:1.03 KB
However, I may have figured out what the problem is. The "hal.get_value ()" command works in LinuxCNC version 2.8.1 but not 2.7.14. I guess this command only works in newer versions, doesn't it?
5 years 6 months ago #205511 by elisa
However, I found the "s.actual_position" command in the documentation which also seems to work in version 2.7.14. If I understand correctly, this command reads the linuxcnc status and I can update the "current joint position" with the s.poll () command.
I will write a post to help everyone who has problems with these things!
Thank you all!
5 years 6 months ago #205572 by andypugh
Why are you using 2.7.14? 2.8 has been released for more than 6 months.
What kind of machine are you working with? 2.8 is significantly better for non-cartesian machines.
Time to create page: 0.079 seconds
