Which communication port/protocol for VFD
4 years 8 months ago #235380 by Tarja
Hi, I could get a VFD, where I can chose the communication protocol.
What would be the best for linuxcnc?
  1. CANopen/motion RJ45
  2. Ethernet TCP/IP (Modbus TCP, Ethernet IP)
  3. ProfiNet (Link Layer Discovery Protocol)
  4. CANopen SUB9 (canopen, canmotion)
  5. Ethercat
  6. Profibus
  7. DeviceNET
Thanks for your help
by
Tarja
4 years 8 months ago - 4 years 8 months ago #235645 by Aciera
Actually most common is analog and step/direction.
From your list I'd say Ethercat might work.
Modbus is also used but using the serial port not the TCP flavour.
Mind you it would also depend on what else you need to interface to (eg the servo drives).
Last edit: 4 years 8 months ago by Aciera.
4 years 8 months ago #235805 by Tarja
So if I understood right modbus only works with serial bus but not on ethernet
Maybe I will try ethercat just for fun
4 years 8 months ago #235812 by HansU
Modbus TCP is also usable, at least if you use the MB2HAL component.
Maybe the VFD Modbus drivers are only using Modbus RTU, I don't know.
4 years 8 months ago #235814 by Aciera
Thanks hansu. I was not aware of that.
  • Perep1989
  • New Member
  • New Member
4 years 8 months ago #236089 by Perep1989
Replied by Perep1989 on topic Which communication port/protocol for VFD
We then look at the different communication ports and protocols that they use.
Time to create page: 0.053 seconds
