Dear all,
I'm a bit uncertain where to place this question as I'm puzzled where my issue comes from...
I have managed to setup a basic 3-axis machine just for learing the trade with a RPI talking to a Mesa 7i76e with open-loop steppers. The machine is basically running and ran several examples, that's how far I am. Mastering the CAM side seems to be the issue...
Whenever I load some self-generated NGC files I see some strange tool paths way up in the air and outside the machine's limits - see attached screenshot, that thing in the red circle. The strange thing is that this happened with two different CAM setups: First I tried a stone-old Catia V5R18 CAM to which I have very limited access through my old university CAD pool but that was just because I was used to this 15 years ago during a project. I've used the FANUC-PP which comes with Catia, btw. I then switched to Fusion 360 which I intend to use for the moment - however the same thing happened (the screenshot actually shows the F360 example). As I initially exported the CATPart and imported it into F360 via STEP I suspected some issue there - however the same issue happened when I created native geometry in F360. I've double checked the *.ngc files with NC corrector and there at least the F360 code looks spot-on.
I'm a bit lost as where to search for the root cause to be honest. As it happends with both CAM systems I'm tempted to think that I did something wrong in the LinuxCNC config but that should also show in the examples, shouldn't it?
Maybe somebody can shed some light on this....
EDIT: I've added the F360 file now. I can't even find a Z=450 reference in there. Sorry, but I'm completely lost.... image missing /media/kunena/emoticons/unsure.png
Best regards,
Tim
