Hello All,
I made a 10mm x 12mm square pocket and a "matching" square cutout/contour. The pocket was more like 9.6 x 11.6 and the cutout more like 10.4 x 12.4. My end mill is 0.8mm. I went through a bunch of fussing with scaling inside of fusion to get the squares just right. Then moved on to a set of donuts with island applying the same scaling. It's a nightmare. Then if i do manage to get it just right I have a bunch more to do (not really but there are other things i'd like to use this technique for).
So over in the fusion forum a person is telling me to use the tool diameter offsets within linuxcnc. I can not find this anywhere. I've tried changing the tool diameter inside of the tool table, saved, reloaded and absolutely no change in the carve. I figured there wouldn't be but it was worth a shot. The only tool offset I can find anywhere is the length of the tool.
Thank you,
