Problems following the design path
4 years 2 weeks ago - 4 years 2 weeks ago #254440 by Nest
Hi, I have a problem when making the designs, the machine does not follow all the routes written in the Gcode.
My card is a MESA 7I96, my CNC is a 3040Z-DQ and the LinuxCNC is 2.8 version
In the image you can see how the design is:
image missing https://i.imgur.com/xPA5HCH.png
In this image is how the machine makes the design
image missing https://i.imgur.com/ei3jmHw.jpg
And in this image is the screen of linuxCNC.
image missing https://i.imgur.com/TlXAtls.png
I have tried other Gcode generators and they all do the same thing, I have tried other versions of the design creation software and there are no changes.
Does anyone know what's going on?
Last edit: 4 years 2 weeks ago by Nest.
4 years 1 week ago #254473 by JPL
This could be trajectory control related. See here: linuxcnc.org/docs/2.6/html/common/User_C...c:trajectory-control
Also, this could be related to acceleration/speed.
4 years 1 week ago #254480 by cakeslob
Probably gonna be a G61-g64 thing, have a look at this section. you will need to find the ideal settings for your machine
linuxcnc.org/docs/stable/html/gcode/g-code.html#gcode:g61
What was the conclusion on changing the default setting in linuxcnc >?
4 years 1 week ago #254481 by tommylight
Slow acceleration, use
G64 P0.1
for metric, 0.1 is 0.1mm or the tolerance it can weer off the path.
It has to be at the top of the gcode, and if you stop and continue, enter it in MDI before run from here.
ASUS ROG Crosshair VIII Impact - AMD X570
4 years 1 week ago #254499 by HansU
The default value for the blending tolerance was changed to 0.001 inches / 0.0254 mm.
4 years 1 day ago #255577 by Nest
Hi, sorry for the delay in answer... I have added the G61 code and now it works fine, the G64 P- Q- gave me some problem.
image missing https://i.imgur.com/j6q4RQ2.png
image missing https://i.imgur.com/ZS0V6R1.jpg
Time to create page: 1.493 seconds
