Retain G43
3 years 3 months ago #276575 by zz912
Retain G43 was created by zz912
Am I using RETAIN_G43 correctly?
I would expect the G43 to start automatically after every tool change.
The behavior is the same in both AXIS and Gmoccapy.
3 years 3 months ago #276640 by andypugh
Replied by andypugh on topic Retain G43
I think that retain G43 only takes effect if you have programmed G43 once (possibly as a startup G-code)
3 years 3 months ago #276645 by zz912
Replied by zz912 on topic Retain G43
My startup code:
RS274NGC_STARTUP_CODE = G17 G21 G40 G43 G54 G64P0.005 G80 G90 G94 G97 M5 M9
If I have:
RETAIN_G43 = 1
After a toolchange, the Z correction takes 0.
If I have:
RETAIN_G43 = 0
After a toolchange, the Z correction takes on the value of the last selected tool.
3 years 3 months ago #276648 by newbynobi
Replied by newbynobi on topic Retain G43
Than it seems not to work as it should :-(
OK that means I need to fix that on September meeting.
gets priority 2 of 6 ;-)
Norbert
3 years 2 months ago #278355 by pmcstoneinc
Replied by pmcstoneinc on topic Retain G43
Can confirm G43 is not retained after a consecutive commanded coordinate move. Preview shows visually but its not being added to coordinate moves
The following user(s) said Thank You: zz912
3 years 2 months ago #278359 by zz912
I would like to ask you to explain your post more simply. I struggle with English. I understand the words you are saying, but I don't know what you mean.
In the video you need to watch:
- "Z" offset tool
- Coordinate "Z" in DRO
- preview
- what happens when I start the G43
I think It is wierd.
Time to create page: 0.203 seconds
