Biesse Rover B 7.40FT
3 years 3 months ago #276714 by vruxik
Biesse Rover B 7.40FT was created by vruxik
Hey LinuxCNC fam,
I have a Biesse Rover B 7.40FT where the computer (specifically the HDD) just bit the dust. If I can't get the configuration back, I'll need to sort something out. I've been reading some posts on people who have gotten LinuxCNC working on their Biesse machines, and I'm just wondering what I'm in for if I decide to go that route.
The machine is from 2004, so it's decently old, but aside from the PC, still works well.
Any thoughts, tips, or advice would be greatly appreciated.
Thank you!
3 years 2 months ago #276770 by rmu
Replied by rmu on topic Biesse Rover B 7.40FT
I did a conversion of a much older machine (1993) with analog servo amplifiers and I/O modules with 5V TTL interface into the control.
It seems your machine uses some kind of serial field bus to connect I/Os - those you would probably have to replace. The really interesting question is how the controller is talking to the servos. AFAICT there are no servo amplifiers visible in your photos.
3 years 2 months ago #276884 by vruxik
Replied by vruxik on topic Biesse Rover B 7.40FT
Thanks for the input. Much appreciated!
Where you recommend I begin my research into this? I have all the manuals and schematics for the machine.
3 years 2 months ago #276885 by Aciera
Replied by Aciera on topic Biesse Rover B 7.40FT
Most important question is:
What is the command interface of the motor drives? (ie analog, step/dir etc.)
If unsure post a picture of the drive type plate and/or the relevant pages from the schematics.
3 years 2 months ago - 3 years 2 months ago #277210 by rmu
If you have schematics and all manuals it should be straightforward to find manufacturer of servos motors/amps and interface.
Last edit: 3 years 2 months ago by rmu.
2 years 10 months ago #287092 by craigs711btm
Replied by craigs711btm on topic Biesse Rover B 7.40FT
I have started a older machine the rover 15 it was pretty straight forward to get most bits working.
these will almost defiantly be analogue signal Yaskawa drives. I think yours might be Metrolink though with makes it bit of a pain. add a picture from the front of the cab where the vfd and drives are
Time to create page: 0.103 seconds
