home button
  • JT
  • JT's Avatar Topic Author
  • Administrator
  • Administrator
27 Sep 2023 12:31 #281715 by JT
home button was created by JT
Attach your hal and ini file and how did you create the configuration?
JT
27 Sep 2023 17:07 #281725 by Aciera
Replied by Aciera on topic home button
For jogging after homing you would connect your pendant like this (example for x axis):
net jog-x-pos <= your_pendant_jog_x_plus_signal => halui.axis.x.plus
net jog-x-neg <= your_pendant_jog_x_minux_signal => halui.axis.x.minus
24 Oct 2023 07:05 #283668 by Aciera
I try your solution but it doesn't work.
not much to go on I'm afraid. For assistance please share your current config and describe what is not working.
24 Oct 2023 07:39 #283675 by Aciera
Have you checked that the pin ' hm2_7i76e.0.7i73.0.1.input-08' goes true when you press the button? (eg using 'halshow')
I presume you can jog the x-axis using the buttons on the GUI.
24 Oct 2023 07:46 #283676 by Aciera
Note that this is only going to work AFTER homing the machine.
24 Oct 2023 09:30 #283685 by Aciera
but my code true and blinking
Not quite sure what you mean.  So ' hm2_7i76e.0.7i73.0.1.input-08' goes true when you press your button connected to the 7i73 and you can jog using the buttons in the GUI?
24 Oct 2023 09:32 #283686 by Aciera
Just to be clear, you want to check that ' hm2_7i76e.0.7i73.0.1.input-08' goes true in LinuxCNC using the 'Show HAL configuration' or 'Hal meter' tools.
24 Oct 2023 14:38 - 24 Oct 2023 14:44 #283710 by Aciera
So can you jog the x-axis using the button in the GUI (ie AXIS, GMOCCPY, QTDragon or whatever you are using)?
You should be able to see the pin 'hm2_7i76e.0.7i73.0.1.input-08' go true whenever you press the button that is connected to the mesa 7i73. If you do not see that change then there is a problem with the wiring of the button.
Also please attach your current hal and ini files so I'm not poking around in the dark.
Last edit: 24 Oct 2023 14:44 by Aciera.
Moderators: PCWjmelson
Time to create page: 0.901 seconds
