Keyboard input occasionally goes unresponsive
3 years 3 weeks ago #282731 by dberndt
Hey folks, I'm looking for some suggestions about where to go next in troubleshooting a keyboard issue.
Running 2.9pre1, RIP, Axis, on linux mint 21 using xfce 4.16/xfwm4 on preempt_rt 6.1.20-1
Everything works normally and well most of the time. I use the machine a few times a week for small projects and linuxcnc works, is stable, usable, no keyboard issues, no issues at all really.
But... every once in a while, it seems the keyboard input to linuxcnc gets frozen, or lost, or somehow delayed? I don't really know what to look at to deduce further the nature of the error.
-When the keyboard issue happens Linuxcnc is no longer responsive to any keyboard inputs. Even things like alt+f to open the file menu,
-The problem might tend to start happening when I spam a bunch of keys in/am being productive. An example might be reloading an NGC file via ctrl+r then F5 for MDI and then intending to do a tool change via m6 but finding that I can't type into the MDI window, or anywhere else... This is a suggestion of what I think may be happening, but it's not easily repeatable for me.
-Everything you can do in linuxcnc with a mouse still works.
-The keyboard still works in every other app, the terminal, all the other virtual consoles, etc
-Windows manager things still work, I can resize the linuxcnc window with the mouse, I can resize/minimize/maximize/etc the linuxcnc with windows manager hotkeys.
-Virtual/on screen keyboard is provides not difference from real keyboard
-Unplugging the keyboard and replugging it makes no difference. adding a second keyboard does not help, removing all physical keyboards and using on screen keyboard doesn't help, using a keyboard over VNC does not work.
-It might be the case that if left for a long enough period of time (overnight) the keyboard responsiveness returns, but my sample size on that is very small and it may not be an accurate statement.
-Restarting linuxcnc seems to fix the issue. But restarting linuxcnc and re-homing in the middle of a part is a bit of a gamble as to how well my home switches repeat.
Does anyone have any suggestions as to what I can do to track this down further where the keystrokes are disappearing to? I guess that means investigating axis.py? Are there any other layers to the onion or logging I can turn on/investigate?
3 years 3 weeks ago #282743 by tommylight
I would assume with quite some certainty that it is a USB keyboard, so if the PC has a PS/2 port and you have an older keyboard with PS/2 connector, test that, see if it gets rid of the issue.
You can also open a terminal and type
sudo top
then use LinuxCNC and watch top to see what is using CPU cycles when the issue happens, it would be at the top of TOP list.
2 years 11 months ago #285762 by dberndt
Bringing this one back up as I've had the issue show up a few times recently.
Here's a path to recreation
Get a relatively large ngc, say a few megs, something that'll take a few seconds to load.
Load the file, or use reload/ctrl+r, all will recreate the issue
When the reload is happening and the progress bar is visible at the bottom of axis, press some keys.
When I do this my keyboard becomes non-responsive in axis until i restart linuxcnc.
2 years 11 months ago #285931 by bkt
you try to change keyboard right? after these when these things happens for first open "resources" app (not know name in debian so) fork check level of usages of ram and cpu )....
2 years 11 months ago #286139 by dberndt
Yes. I've tried all the keyboard things... Keyboard replacement, etc.
As per my first post, During this condition the keyboard still works everywhere else. Even the on screen keyboard is affected by this problem, it continues to work in all other apps but not in linuxcnc.
Has anyone tried to duplicate?
2 years 11 months ago #286642 by bkt
never see these .... seems wm problem ....
Time to create page: 0.270 seconds
