That's the ideaYou might want to use feed-hold to pause the axis motion except when the spindle is at the top of the stroke.
I don't mind having each hole in a separate line of code, I hope they can be generated using a simple ngcgui algorithm (e.g. drilling on a milling machine)Do you expect to have a separate G-code line for every punched hole?
the head is a manual changeDo you have a multi-tool head?
