Rotary encoder for feed/spindel override wiring Meas 7i77
2 years 10 months ago #289184 by CNCDoc
Has two rotary encoders. Which I intended to use as a feed/spindle override. Can I use encoder input 3/4?
2 years 10 months ago #289188 by PCW
Does that device have a quadrature output?
It's not clear from the markings.
2 years 10 months ago #289189 by CNCDoc
Yes it is quadrature.
2 years 10 months ago #289190 by PCW
Probably best connected to the 7I77 MPG inputs  if you want 1X mode
but will work on regular encoder inputs if it has 5V signals
2 years 10 months ago #289193 by CNCDoc
I have one MPG connected.  Are there 3 "MPG" inputs?
2 years 10 months ago #289199 by PCW
No, there are only inputs for two MPGs on the 7I77 field I/O pins
Time to create page: 0.343 seconds
