How to run two programs simultaneously
2 years 9 months ago #290353 by wisao
Hello everyone, everything good?
Would it be possible to run two machining programs simultaneously within Linux CNC?
I have a lathe with 2 spindles, each spindle has its respective X and Z.
So I can work with simultaneous cycles at the same time.
2 years 9 months ago #290354 by Aciera
This is currently not possible.
If you are experimental you could try running two PCs with LinuxCNC on each and then think of a way to control gcode execution of one PC with the other.
2 years 9 months ago #290368 by wisao
Do you know if anyone has tried this?
Would it be very difficult to make this modification in Linux?
My objective would be to control a machine with 6 spindles
2 years 9 months ago #290369 by wisao
a machine like this:
2 years 9 months ago #290370 by Aciera
Well, now you have gone from a lathe with 2 spindles to a machine with 6 in two posts.
I don't know of any reports on using more than one instance of LinuxCNC, so it would be experimental even for 2 spindles let alone for 6.
2 years 9 months ago - 2 years 9 months ago #290372 by Mecanix
Yes. I know of someone who've accomplished a dual-workstation synchronized motion controller. One of them servicing gcode and acting as a "wait-server" and the other servicing gcode only. Wasn't made with linuxcnc, however the same can be achieved given a significant amount of passion.
Synchronized channels are only possible if post-processed as such. Often using a "wait cycle" or M function for the sync flag, hence the wait-server required to sync both workstations in the context of what member Aciera rightly advised already. You'll also need to acquire a CAM that is adapted for a multi channel machine-tool -the like showcased in your video.
Last edit: 2 years 9 months ago by Mecanix.
Time to create page: 0.301 seconds
