How to set a Bit in HAL
2 years 9 months ago #292032 by wisao
Hey guys,
I'm using the LIMIT3 component linuxcnc.org/docs/html/man/man9/limit3.9.html
how do I activate limit3.0.enable ?
I need to activate it with one parallel port button and deactivate it with the another.
# Limit 3 Enable Set / Clr
net limit3-0-set <= parport.0.pin-12-in-not
net limit3-0-clr <= parport.0.pin-13-in-not
# net limit3-0-set => setp limit3.0.enable 1
# net limit3-0-clr => setp limit3.0.enable 0
The last two commented lines are giving me an error.
What I want to do is when I turn on pin 12, Enable is 1 and when I turn on pin 13, Enable is 0
2 years 9 months ago #292043 by zz912
2 years 9 months ago #292098 by wisao
Replied by wisao on topic How to set a Bit in HAL
Can you please show me a pratical example ? please
2 years 9 months ago - 2 years 9 months ago #292100 by Aciera
Replied by Aciera on topic How to set a Bit in HAL
I think 'toggle2nist' is for a single momentary button to change the states of two complementary output signals. What is needed here is the opposite, two input signals to change the state of one output signal.
Are your input signals on the parallel port momentary signals (ie signal goes high when you press the button)?
[edit]
Maybe an sr latch would do the job (using two 'and2' and two 'not' components):
www.educative.io/answers/the-sr-latch
There may be a ready made component for this but I cannot find one.
Last edit: 2 years 9 months ago by Aciera.
2 years 9 months ago #292109 by PCW
Replied by PCW on topic How to set a Bit in HAL
Yes, the flipflop component will work for this
since it has set and reset inputs:
loadrt flipflop
addf flipflop.0 servo-thread
loadrt limit3
addf limit3.0 servo-thread
net limit3-0-set <= parport.0.pin-12-in-not  flipflop.0.set
net limit3-0-clr <= parport.0.pin-13-in-not  flipflop.0.reset
net limit3-enable flipflop.0.out limit3.0.enable
The following user(s) said Thank You: tommylight, zz912, wisao
