undefined symbol: kinematicsSwitch
2 years 6 months ago - 2 years 6 months ago #298369 by alpha8196
So I'm quite new to all this and was trying to run linuxcnc on a Pi5, and I was trying to see if I can at least get a stepper spinning using the gpio pins.
I ran through the stepconf wizard and then replaced the content in the .hal file with the demo hal file .
Linuxcnc failed to start with the following message
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_CONFIG_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.9.2
Machine configuration directory is '/home/cnc/linuxcnc/configs/actuator_v0'
Machine configuration file is 'actuator_v0.ini'
INIFILE=/home/cnc/linuxcnc/configs/actuator_v0/actuator_v0.ini
VERSION=1.1
PARAMETER_FILE=linuxcnc.var
TPMOD=
HOMEMOD=
TASK=milltask
HALUI=halui
DISPLAY=axis
COORDINATES=X Y Z A
KINEMATICS=trivkins coordinates=XYZA
Starting LinuxCNC...
Found file(REL): ./actuator_v0.hal
Debug file information:
Note: Using POSIX realtime
motmod: dlopen: /usr/lib/linuxcnc/modules/motmod.so: undefined symbol: kinematicsSwitch
./actuator_v0.hal:2: waitpid failed /usr/bin/rtapi_app motmod
./actuator_v0.hal:2: /usr/bin/rtapi_app exited without becoming ready
./actuator_v0.hal:2: insmod for motmod failed, returned -1
3107
Stopping realtime threads
Unloading hal components
what should I do to fix this?
here's the hal and ini file used
File Name: actuator_v0.hal
File Size:1.91 KB
File Name: actuator_v0.ini
File Size:3.07 KB
Last edit: 2 years 6 months ago by alpha8196. Reason: attached hal and ini file
2 years 6 months ago #298371 by Cant do this anymore bye all
Post your hal & ini files, the actual one your are using. It helps, it really does.
2 years 6 months ago #298384 by alpha8196
they are now attached to the post
2 years 6 months ago #298404 by Cant do this anymore bye all
No step & dir for A axis in your hal file
2 years 6 months ago #298406 by tommylight
Also, why switchable kinematics on a 4 axis machine? Is there any machine that benefits from it?
2 years 6 months ago #298418 by Aciera
I think the error message may be misleading as the config uses the standard 'trivkins' kinematic.
Time to create page: 0.330 seconds
