MPG choppy motion
2 years 6 months ago #298953 by natholego11
Good evening,
I recently got a 4 axis pendant similar to this one. PCW helped tremendously with getting it wired up and getting the firmware for my 7i96 working.  Thank you Peter!
now that I have motion, I am getting very choppy movements on the actual machine, is there a way to smooth out the motion coming from the pendant?  I read a little about lowpass filters, not sure if that would be a good route to go, but im not entirely sure how to incorporate it into my hal file.
I have a custom hal for the pendant inputs.
Any feedback on this would be much appreciated!
2 years 6 months ago #298958 by spumco
Replied by spumco on topic MPG choppy motion
axis.L.jog-accel-fraction is the first thing to try.
"1" = 100% accel value set in the INI file for that axis
Add ("L" is the axis letter):
setp axis.L.jog-accel-fraction 0.5
to your hal file for each axis and see if it helps.  You can even turn it down farther, but be cautious as too low of a setting can result in 'lazy' responses to the MPG.
2 years 6 months ago #298983 by natholego11
Replied by natholego11 on topic MPG choppy motion
Thank you, Ill try this tonight. would it look something like this:
# This file will not be overwritten when you run PNCconf again # if MPG outputs a quadrature signal per click set x4-mode to 1 # if MPG outputs 1 pulse per click set x4-mode to 0 #             --- JOG INCREMENTS--- # --- JOG-INCR-A --- net jog-incr-a     <=  hm2_7i96.0.inm.01.input-08-not # --- JOG-INCR-B --- net jog-incr-b     <=  hm2_7i96.0.inm.01.input-09-not # --- JOG-INCR-C --- net jog-incr-c     <=  hm2_7i96.0.inm.01.input-12-not #            --- JOINT SELECTIONS ---  #--- JOINT-SELECT-X --- net joint-select-x     <=  hm2_7i96.0.inm.01.input-02-not # --- JOINT-SELECT-Y --- net joint-select-y     <=  hm2_7i96.0.inm.01.input-03-not # --- JOINT-SELECT-Z --- net joint-select-z     <=  hm2_7i96.0.inm.01.input-04-not # --- JOINT-SELECT-A --- net joint-select-a     <=  hm2_7i96.0.inm.01.input-05-not # ---jogwheel signals to mesa encoder net axis-selected-count     <= hm2_7i96.0.inm.01.enc0-count # section 5 #       for axis x MPG # uncomment the jog-vel-mode you want to use # comment out the ones you dont # mode 1 is typically used #setp    axis.x.jog-vel-mode 0 setp    axis.x.jog-vel-mode 1 setp    axis.x.jog-accel-fraction 0.5 # net selected-jog-incr    =>  axis.x.jog-scale net joint-select-x       =>  axis.x.jog-enable net axis-selected-count =>  axis.x.jog-counts # section 6 #       for axis y MPG # uncomment the jog-vel-mode you want to use # comment out the ones you dont # mode 1 is typically used #setp    axis.y.jog-vel-mode 0 setp    axis.y.jog-vel-mode 1 setp    axis.y.jog-accel-fraction 0.5 # net selected-jog-incr    =>  axis.y.jog-scale net joint-select-y       =>  axis.y.jog-enable net axis-selected-count =>  axis.y.jog-counts  # section 7 #       for axis z MPG # uncomment the jog-vel-mode you want to use # comment out the ones you dont # mode 1 is typically used #setp    axis.z.jog-vel-mode 0 setp    axis.z.jog-vel-mode 1 setp    axis.z.jog-accel-fraction 0.5 # net selected-jog-incr    =>  axis.z.jog-scale net joint-select-z       =>  axis.z.jog-enable net axis-selected-count =>  axis.z.jog-counts    #NOT USED-----1 of the below axis must be be commented out ( sections 8-10 )----NOT USED # a and c are typically used # section 8 #       for axis a MPG # uncomment the jog-vel-mode you want to use # comment out the ones you dont # mode 1 is typically used #setp    axis.a.jog-vel-mode 0 setp    axis.a.jog-vel-mode 1 setp    axis.a.jog-accel-fraction 0.5 net selected-jog-incr    =>  axis.a.jog-scale net joint-select-a       =>  axis.a.jog-enable  net axis-selected-count      =>  axis.a.jog-counts   # section 9 #       for axis b MPG # uncomment the jog-vel-mode you want to use # comment out the ones you dont # mode 1 is typically used #setp    axis.b.jog-vel-mode 0 #setp    axis.b.jog-vel-mode 1 #net selected-jog-incr    =>  axis.x.jog-scale #net joint-select-b       =>  axis.x.jog-enable  #net selected-count      =>  axis.x.jog-counts # section 10 #       for axis c MPG # uncomment the jog-vel-mode you want to use # comment out the ones you dont # mode 1 is typically used #setp    axis.c.jog-vel-mode 0 #setp    axis.c.jog-vel-mode 1 #net selected-jog-incr    =>  axis.c.jog-scale #net joint-select-c       =>  axis.c.jog-enable #net axis-selected-count =>  axis.c.jog-counts      # jog increment # section 11 # note jog increments are in inches or standard measurements #  # make sure the setp jogincr.in## has a - next to its scale number # # if you want to reverse the encoder direction remove the - # from its scale number #setp hm2_7i96.0.inm.01.enc0-counter-mode 1 net jog-incr-a          =>  jogincr.sel0 net jog-incr-b          =>  jogincr.sel1 net jog-incr-c          =>  jogincr.sel2 net selected-jog-incr   <=  jogincr.out-f     setp jogincr.debounce-time      0.200000     setp jogincr.use-graycode       false     setp jogincr.suppress-no-input  false      setp jogincr.in00         0.1000     setp jogincr.in01          0.1000     setp jogincr.in02          0.0100      setp jogincr.in03         0.0010     setp jogincr.in04          0.0010      setp jogincr.in05         0.0010      setp jogincr.in06         0.0500      setp jogincr.in07         0.1000      setp jogincr.in08         0.1000      setp jogincr.in09         0.1000      setp jogincr.in10         0.1000      setp jogincr.in11         0.1000      setp jogincr.in12         0.1000      setp jogincr.in13         0.1000      setp jogincr.in14         0.1000      setp jogincr.in15         0.1000
2 years 6 months ago #299006 by spumco
Yep, looks like a good starting point.
2 years 6 months ago #299363 by natholego11
so, that helped on the X and Y axis. but the Z is still very choppy, almost regardless of what value I use there.
other thoughts?
2 years 6 months ago #299365 by spumco
Does it change at all when you set z-accel-fraction way low?  If not, you may have a typo in your hal file.
You can check if it's active using halshow.  Find the z-axis jog-accel-fraction pin/parameter and you can change it directly in halshow.
If the response changes a little, but not much... then do you have any mechanical issues? Backlash or sloppy ballscrew end bearings?
Time to create page: 0.282 seconds
