[resolved]Ethercat servo spindle orient problem while using M19 ?
2 years 3 months ago - 2 years 3 months ago #304871 by timaer
Hi,everyone
    I've tried to follow the orient hal map to build a hal to test if it can be workable for orient ,but met some problem. while running M3 S100,M4 S100 such command it's all OK, but when I tried to use M19 R180 ,it didnt rotate at all. Using halshow display GUI,I noticed that while I run M3/M4 command,the spindle.on is true,but while I run the M19 R180  ,it is false.I dont know if it is the reason.Wish someone could help me ,point out where is the error of my hal .Thanks
# CIA 402 example snippet Hal
# Setup
loadrt [KINS]KINEMATICS
loadusr -W lcec_conf ethercat-conf.xml
loadrt lcec
loadrt cia402 count=2
loadrt pid names=pos-pid,velo-pid
loadrt orient count=1
loadrt mux2 count=1
# Functions servo-thread
addf lcec.read-all servo-thread                 #reading from servo
addf cia402.0.read-all servo-thread
addf cia402.1.read-all servo-thread
addf motion-controller servo-thread             #linuxcnc module ,cia402 module as a translator
addf pos-pid.do-pid-calcs servo-thread
addf velo-pid.do-pid-calcs servo-thread
addf orient.0 servo-thread
addf mux2.0 servo-thread
addf cia402.0.write-all servo-thread
addf cia402.1.write-all servo-thread            #writing to servo
addf lcec.write-all servo-thread
#nets
net emc-enable => iocontrol.0.emc-enable-in
sets emc-enable 1
#config
# Joint 0
setp cia402.0.csp-mode 0
setp cia402.0.velo-scale 166
#FOR SPINDLE
setp velo-pid.deadband 0.3      #limit pid tolerance
setp velo-pid.maxoutput 500     #limit pid maxoutput to protect
setp pos-pid.deadband 0.3
setp pos-pid.maxoutput 500
net 0-statusword                                 lcec.0.0.cia-statusword  => cia402.0.statusword
net 0-opmode-display                             lcec.0.0.opmode-display  => cia402.0.opmode-display
net 0-drv-act-pos                                lcec.0.0.actual-position => cia402.0.drv-actual-position
net 0-drv-act-velo                               lcec.0.0.actual-velocity => cia402.0.drv-actual-velocity
net 0-speed-fb                                   cia402.0.velocity-fb     => velo-pid.feedback
net 0-pos-fb        pos-pid.feedback        <=   cia402.0.pos-fb          => orient.0.position
#for spindle orient
#from linuxcnc motion to cia402 / cia402 to motion
#net 0-spindleON     spindle.0.on             => cia402.0.enable
#net 0-target-speed  spindle.0.speed-out      => cia402.0.velocity-cmd
net 0-home-index    spindle.0.index-enable   => cia402.0.home
net 0-spindleON     velo-pid.enable          <= spindle.0.on         => cia402.0.enable
net 0-target-speed  spindle.0.speed-out      => velo-pid.command
net 0-orient        pos-pid.enable           <= spindle.0.orient     => orient.0.enable  => mux2.0.sel
net 0-angle         spindle.0.orient-angle   => orient.0.angle
net 0-orient_topos  orient.0.command         => pos-pid.command
net 0-pospid-tomux  pos-pid.output           => mux2.0.in1
net 0-velopid-tomux velo-pid.output          => mux2.0.in0
net 0-muxtoabs-final-speed      mux2.0.out   => cia402.0.velocity-cmd
net 0-amp-fault     spindle.0.amp-fault-in   <= cia402.0.drv-fault
#from cia402 to servo
net 0-controlword         cia402.0.controlword         => lcec.0.0.cia-controlword
net 0-modes-of-operation  cia402.0.opmode              => lcec.0.0.opmode
net 0-drv-target-pos      cia402.0.drv-target-position => lcec.0.0.target-position
net 0-drv-target-velo     cia402.0.drv-target-velocity => lcec.0.0.target-velocity
# Joint 1
setp cia402.1.csp-mode 1
setp cia402.1.pos-scale 166
#from servo to cia402
net 1-statusword      lcec.0.1.cia-statusword  => cia402.1.statusword
net 1-opmode-display  lcec.0.1.opmode-display  => cia402.1.opmode-display
net 1-drv-act-pos     lcec.0.1.actual-position => cia402.1.drv-actual-position
net 1-drv-act-velo    lcec.0.1.actual-velocity => cia402.1.drv-actual-velocity
net 1-home-index joint.1.index-enable   => cia402.1.home
net 1-enable     joint.1.amp-enable-out => cia402.1.enable
net 1-amp-fault  joint.1.amp-fault-in   <= cia402.1.drv-fault
net 1-pos-cmd    joint.1.motor-pos-cmd  => cia402.1.pos-cmd
net 1-pos-fb     joint.1.motor-pos-fb   <= cia402.1.pos-fb
net 1-controlword         cia402.1.controlword         => lcec.0.1.cia-controlword
net 1-modes-of-operation  cia402.1.opmode              => lcec.0.1.opmode
net 1-drv-target-pos      cia402.1.drv-target-position => lcec.0.1.target-position
net 1-drv-target-velo     cia402.1.drv-target-velocity => lcec.0.1.target-velocity
Last edit: 2 years 3 months ago by timaer.
2 years 3 months ago #304873 by Aciera
for M19
'spindle.on' is false
'spindle.orient' is true
Have a look at section 2:
linuxcnc.org/docs/devel/html/config/core...html#sec:motion-pins
When you call M19 what do you see when you watch this signal:
The following user(s) said Thank You: timaer
2 years 3 months ago - 2 years 3 months ago #304874 by timaer
Hi,Thank you ,Aciera.I just runned M19 R180,and the 0-muxtoabs-final-speed value is 0.2, is this the reason why the orient not working ?
BTW,"for M19 'spindle.on' is false 'spindle.orient' is true ",that's the exact situation while I runned M19,but still ,the orient action not happed.
2 years 3 months ago #304876 by Aciera
Looks like the spindle drive is only enabled when using M3/M4:
I guess you need to enable the spindle drive if 'spindle.0.on' is true OR 'spindle.0.orient' is true
So maybe try inserting an 'OR2' component with the 'spindle.0.on' signal on input 0, 'spindle.0.orient' signal on input 1 and the output going to 'cia402.0.enable'
2 years 3 months ago - 2 years 3 months ago #304882 by timaer
Hi,Aciera,I've modified it following your suggestion.it seems to be still not working.before modifying ,the final value is always 0.2 and after modifying ,now the value jump over again in 0.2 and -0.2 .
# Setup
loadrt lcec
loadrt mux2 count=1
loadrt or2 count=1
addf or2.0 servo-thread
#nets
sets emc-enable 1
#config
# Joint 0
#FOR SPINDLE
#for spindle orient
net 0-spindleon-normal velo-pid.enable <= spindle.0.on => or2.0.in0
net 0-orient pos-pid.enable <= spindle.0.orient => orient.0.enable => mux2.0.sel => or2.0.in1
net 0-spindleON or2.0.out => cia402.0.enable
# Joint 1
2 years 3 months ago #304889 by Aciera
Besides the pins you were already watching also have a look at the 'orient' component pins:
linuxcnc.org/docs/html/man/man9/orient.9.html
This should verify if you are getting any useful signal to 'pos-pid.command'
I see that you have not connected 'orient.0.mode' to 'spindle.0.orient-mode'. Not sure if the 'orient' component has a default value for its 'mode'-pin but you may want to make the connection just to be sure.
Note that I know nothing about the EtherCAT side of things at all, including the 'cia402' component.
Time to create page: 0.412 seconds
