Chasing Threads and Re-Threading
- Toyota1zz
30 Dec 2024 10:13 #317665
by Toyota1zz
Chasing Threads and Re-Threading was created by Toyota1zz
- Thank you received: 6847
30 Dec 2024 10:34 #317668
Replied by tommylight on topic Chasing Threads and Re-Threading
- smc.collins
- Thank you received: 129
30 Dec 2024 14:04 #317676
by smc.collins
Replied by smc.collins on topic Chasing Threads and Re-Threading
to my eyeballs that looks like either a 10mm x 1.25 pitch or a 12mm x 1.25 pitch bolt, both are very common on Toyota engines. Measure the major diameter of the threads. post that up and measure from peak to peak across 2 threads. Push come to shove most hardware stores that have a nice nut bolt isle should have a thread gauge, also Tractor Supply has thread gauges as well. Looking at the condition of the threads, I would get a thread chaser tap, they don't cut they just reform thread. If you can't get that to start, you have 2 options.
1. helicoil or timecert repair
2. tap and drill to the next size
if you end up doing a thread repair or oversize drilling, piece of advice, don't use a fine thread, use a course thread pitchs like 1.5 or 1.75, I have no freaking idea why the hell toyota, nissan and honda have to be so stupid about thread pitch in cast aluminum, but here we are 60 yrs later with the same stupid problems.
- Thank you received: 3740
31 Dec 2024 04:40 #317700
Replied by rodw on topic Chasing Threads and Re-Threading
Metric threads are pretty simple. My guess it would be a metric fine thread 17mm x 1.5mm pitch
So if you don't have a thread gauge, measure 10 threads and see if it is 15mm long.
Then you just need to buy a 17x1.5mm tap.
to size the drill for a metric tap, just deduct the pitch from the diameter. In this case, 17-1.5 = 15.5mm
- timo
- Thank you received: 39
02 Jan 2025 09:26 #317864
by timo
Replied by timo on topic Chasing Threads and Re-Threading
Never came across an M17 bolt (but M17x1 and M17x1.5 taps are available)
Is the hex of the head 17 mm?
In that case it would probably be an M10 bolt as smc.collings already guessed.
M10x1 is common on rear axles for bicycle hubs, so that would be easy to confirm, by screwing the bolt into a nut from a bicycle.
Taps for it are "findable" e.g. Yamawa, Gühring, SUS, Corai, Regal come to mind.
Should it be M10x1 I would probably just make two slots into a hardenend bicycle axle with the angle grinder, then carefully screw it in with some cutting oil to clean up the thread.
Time to create page: 0.280 seconds
