Spindle and VFD control in LINUXCNC
1 year 1 week ago #336896 by Dumitrus
Hello for all!
I'm want to control my spindle with LinuxCNC but I have no idea how to do this. I have a 2.2KW YL620-A VFD and I found in the manual some instructions for wiring and configurations for the VFD but I have no idea what to do in LinuxCNC. I attached an image with the wiring.
Thank you!
1 year 1 week ago - 1 year 1 week ago #336903 by PCW
What you need to do depends entirely on your interface hardware.
What interface hardware do you have?
If this is for a parallel port interface with the particular breakout card pictured,
you would use stepconf  to add a spindle PWM generator to pin 1 for the spindle
analog speed control, and perhaps use the breakout cards relay output for spindle
enable (pin 17)
Last edit: 1 year 1 week ago by PCW.
1 year 1 week ago #336905 by Dumitrus
Yes, I have the same breakout board from the picture. I thought that the spindle speed is controlled by an analog signal with 0 V to 10 V. I found about this in the documentation (spindle control) but I don't know how to implement it.
1 year 1 week ago - 1 year 1 week ago #336907 by PCW
Yes, typical VFDs have an analog 0 to 10V control method.
The breakout shown converts a PWM signal from the PC parallel
port to a 0 to 10V analog signal for the VFD.
Stepconf can set this up:
1 year 1 week ago #336911 by Dumitrus
So I have to connect pin 17 to the VFD? Thank you!
1 year 1 week ago - 1 year 1 week ago #336917 by PCW
Pin 17 on the parallel port activates the relay on the breakout board
That was a suggestion based on the fact that the VFD in your picture
is connected to the breakout boards relay contacts.
The following user(s) said Thank You: Dumitrus
Time to create page: 0.055 seconds
