- Hardware & Machines
- Driver Boards
- Mesa 7I76EU TB2 not working right (TB3 works fine) – need help diagnosing
- adhamamer
10 Apr 2026 05:59 #345384
by adhamamer
Mesa 7I76EU TB2 not working right (TB3 works fine) – need help diagnosing was created by adhamamer
Hi everyone,I’m very new to LinuxCNC and Mesa boards, so I might be missing something basic here, but I’ve been stuck on this for a while and could really use some guidance.I’m working with a Mesa 7I76EU and setting up stepgens in LinuxCNC. When I use TB3 (channel 4), everything works perfectly. The motor moves in both directions, the direction signal changes correctly, and I can clearly see step pulses on the oscilloscope.The issue is with TB2 (channels 0–3). No matter which channel I use, I don’t get proper behavior. At first, measuring to ground made it seem like there was no voltage at all, which confused me. Then I realized these are differential outputs and started measuring across the pairs instead.On TB2, I can see step pulses across STEP+ and STEP− (about 5V differential), so the channel is definitely active. But the DIR signal (DIR+ to DIR−) stays constant at about 5V and does not change when I reverse direction. Also, the step pulses only show up when jogging in one direction, not both.In HALShow, the stepgen for that channel looks active. Enable is true, velocity command changes sign when I jog forward and backward, and position feedback and counts are updating. So from LinuxCNC’s side, it looks like the commands are being generated correctlyWhat’s confusing me is that TB3 works perfectly under the same setup, but TB2 behaves like this. At this point I’m not sure if this is something I’m misunderstanding about configuration or differential signals, or if it could be a partial hardware issue affecting only TB2.Has anyone run into something like this before? Any suggestions on what I should check next would really help.Thanks a lot
- Thank you received: 5220
10 Apr 2026 19:35 #345405
Replied by PCW on topic Mesa 7I76EU TB2 not working right (TB3 works fine) – need help diagnosing
Is it possible that you have the incorrect step mode chosen in your hal file?
(step/dir is mode 0)
- adhamamer
11 Apr 2026 03:00 #345409
by adhamamer
Replied by adhamamer on topic Mesa 7I76EU TB2 not working right (TB3 works fine) – need help diagnosing
Yeah i checked it in halshow under parameters
step_type is 0
step_type is 0
11 Apr 2026 04:16 #345411
The signals are differential but can be used single ended
That is DIR+ and DIR- should both change voltage when
the direction changes but one should change from 0 to 5V and the
other from 5V to 0 (relative to ground)
Measured differentially, you should always measure either
+5V or -5V across the DIR+,DIR- or STEP+,STEP- pins.
- adhamamer
11 Apr 2026 04:29 #345412
by adhamamer
I measured again
from +5V to DIR+ = 5.13V and drops to exactly 5V when jogging in the negative direction
from +5V to DIR- is always at 0V That's for all channels on TB2 1, 2 and 3
Do you think i got a faulty board, Sorry this is getting so frustrating
11 Apr 2026 14:30 #345417
Very weird symptoms...
Probably should be returned for evaluation
As last check on the software side, can you post you hal/ini files?
- Thank you received: 7325
11 Apr 2026 14:56 #345418
Replied by tommylight on topic Mesa 7I76EU TB2 not working right (TB3 works fine) – need help diagnosing
Can you make a new very simple config and test again?
- adhamamer
11 Apr 2026 20:04 - 11 Apr 2026 20:06 #345423
by adhamamer
I tried on a Raspberry Pi 4 with image "image_2026-01-21-raspios-lcnc-2.9.8-trixie-arm64"
and on a Laptop with image "linuxcnc_2.9.8-amd64.hybrid"
and unfortunately i get the same results on both, with the simplest configs i can do, even in the test/tune tab in pnc wizard it acts the same way, Sorry guys i may be missing something really basic here, do you think it might be the firmware?
config name "GG" made on the laptop
Files attached
Files attached
Last edit: 11 Apr 2026 20:06 by adhamamer.
11 Apr 2026 20:08 #345424
The hal and ini file look sane so I would guess its some kind of hardware issue.
So the card should be returned for evaluation
- adhamamer
11 Apr 2026 20:16 #345425
by adhamamer
You think it's worth it to give it another shot with flashing another firmware before returning it or do you advice against that?
- Driver Boards
Time to create page: 0.312 seconds
