7i43 and 7i48
15 years 2 weeks ago #13855 by cmorley
Replied by cmorley on topic Re:7i43 and 7i48
first download this zip file and extract it on your desktop
Attachment custom_firmware-26484f0b23093990330f53245311707b.zip not found
15 years 2 weeks ago #13857 by cmorley
now If you have played with pncconf and saved a file pncconf adds a preference file its called:
.pncconf-preferences
if you haven't saved a file make a dummy one so this file is written.
after that load pncconf again and your firmware SVST6_6 should be available (chose 7i43-4 of course).
If there is a problem check that file.
Its a hidden file so to see it you must
click on show hidden' under 'view' in the file browser.
in that file there should be a line that looks like this:
<property name="customfirmwarefilename" type="string" value="~/Desktop/custom_firmware/firmware.py"/>
If not add it and try again.
15 years 2 weeks ago #13858 by cmorley
I forgot to mention, in case you didnt know to add the PIN file Peter sent you in the folder
/lib/firmware/hm2/7i43-4
probably need root access to do that
15 years 2 weeks ago #13871 by ericson
Replied by ericson on topic Re:7i43 and 7i48
thanks for the reply.
but it does not work.
I added the bit file
and downloaded firmware.py
and extract it on the desktop.
I put the text in the file also,
if it was the right file?
15 years 2 weeks ago - 15 years 2 weeks ago #13873 by cmorley
when you extracted it was it still in the folder named custom_firmware ? It should be.
The text should go in the file named .pncconf-preferences
Then open pncconf from a terminal when the splash screen shows it should say
something like "Pncconf founf extra firmware"
it should also say something like:
/home/chris/Desktop/custom_firmware/firmware.py
You are sure your using 2.5 ( hmm when did you get 2.5?)
Last edit: 15 years 2 weeks ago by cmorley.
15 years 2 weeks ago #13883 by ericson
I have 2.5, but would perhaps not
download from buildbot.linuxcnc.org/ lucid master-rt
Time to create page: 0.095 seconds
