5i25+7i76 I/O linking
10 years 11 months ago #64778 by viski
5i25+7i76 I/O linking was created by viski
Can somebody tell me how to link Output and Inputs from 7i76 board to classic ladder bits ?
An example for 0. output
and example for 0. input
10 years 11 months ago #64779 by andypugh
Replied by andypugh on topic 5i25+7i76 I/O linking
As a general solution, if you load the config without the connections, then open a terminal and type "halcmd show pin" you will get a list of all the HAL pins that you could link together.
You can cut and paste that into a text file (or pipe it directly to a text file if you prefer).
A typical HAL net would be
net i-am-a-signal classicladder.0.in-02 hm2_5i25.0.7i76.0.0.input-00 net i-am-a-signal-in-the-opposite-direction classicladder.0.out-00 hm2_5i25.0.7i76.0.0.output-05
Time to create page: 0.057 seconds
