Stepper configs have suboptimal P term setting
9 years 10 months ago #83920 by guymalpass
Hi Peter,
I'm running a closed loop stepper system using a 7i76, 7i77 and 5i25 and have recently noticed your post about P terms being 1/servo period. I have been using a P term of 170 so decided to try out 1000 (my servo period is 1000000) but I just get oscillation. Is there anything I should be looking at to explain why I am so far off your recommended value?
To clarify my stable settings are P-170 I-0 D-0 FF1-0.994 FF2-0.000025 on master branch.
Thanks,
Guy
9 years 10 months ago #83921 by PCW
For a closed loop system (closed with encoder feedback)
1/T-servo is probably way too much P gain
because of delays from step output to physical motion
Only very tiny delays are present for "local" pid feedback so the 1/T-servo works and matches
the drivers position mode settings (that correct the position error completely in the next servo period)
9 years 10 months ago #83922 by guymalpass
My mistake I thought the post was referring to closed loop setups.
9 years 10 months ago #83923 by PCW
NP, I probably was not clear, its a bit confusing since they are both closed loop
(though one is closed locally to the stepgen position counter)
Time to create page: 0.170 seconds
