Velocity Won't Exceed 6000mm
10 years 7 months ago #71956 by THEQYD
I'm trying to test my stepper drivers in PncConf, but the test window won't allow me to adjust the velocity beyond 6000mm/s.
I don't know what is happening. Please help.
10 years 7 months ago #71995 by Clive S
THEQYD wrote: I'm trying to test my stepper drivers in PncConf, but the test window won't allow me to adjust the velocity beyond 6000mm/s.
360m/min how fast do you want it to go
10 years 7 months ago - 10 years 7 months ago #72329 by andypugh
That is 21kph or 13mph. What are you building?
Last edit: 10 years 7 months ago by andypugh.
The following user(s) said Thank You: THEQYD
10 years 6 months ago #72582 by THEQYD
Replied by THEQYD on topic Velocity Won't Exceed 6000mm
Apologies, the measurements were minutes, not seconds.
10 years 6 months ago #72585 by andypugh
If you need higher speeds than the Wizards allow (though I am not sure why the wizards would enforce limits) then you can hand-editt he maximum velocities in the INI file:
linuxcnc.org/docs/2.7/html/config/ini-config.html
Time to create page: 0.111 seconds
