UPDATE: I tried a "new" complete install of LinuxCNC with the PREMT-RT kernel (closely following the directions from the "Getting LinuxCNC website:
linuxcnc.org/docs/html/getting-started/getting-linuxcnc.html
) and it still does not function well with my 7i76e card (PNCconf and Hal Meter do not work correctly).
I am experiencing the following problems:
Using PNCconf: I can't use the test / tune functions for any axis motor or the spindle. I get the following error when trying to tune either axis stepper drive from within PNCconf:
File "/usr/bin/pncconf", Line 1630, in check_for_rt
eLif Hal.is_rt and not hal.kernel_version == actual_kernel:
AttributeError: 'module" object has no attribute 'kernel_version'
Linuxcnc loads without errors and I can jog each axis, but the "Calibration" screen still will not allow me to test the tune of my motors (it will not allow me to save changes to the INI file either). I realize I can make the changes to my INI file manually and I've done that, but now when I test my inputs, I've found the "Hal Meter" does not work either (can not show change in state of inputs). In addition, when I check the spindle encoder, it does not show the spindle revs correctly. It appears to display the total accumulated counts. :blink:
The weird thing is that if I load the custom Glade "spindle" panel available through PNCconf, that DOES display the spindle revs correctly.
I've verified the input from both HOME switches change state at the 7i76e card, but it appears to do nothing in the Hal Meter in AXIS.
I have also tried a completely different PC, but it does the same thing.
Any help is appreciated.
