Mesa 5i25 and 7i76
  • finemeca
  • Topic Author
  • New Member
  • New Member
10 years 4 months ago #75967 by finemeca
Mesa 5i25 and 7i76 was created by finemeca
Hello,
I'm testing with a mesa 5i25 and 7i76
I flashed with the command:
sudo mesaflash --device 5I25 --write 5i25_7i76x2.bit
Control :
sudo mesaflash --device 5I25 --verify 5i25_7i76x2.bit
tour-mondial@tour-mondial:~/Téléchargements/5i25/configs/hostmot2$ sudo mesaflash --device 5I25 --verify 5i25_7i76x2.bit
Checking file... OK
File type: BIT file
Boot sector OK
Verifying EEPROM sectors starting from 0x100000...
|VVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVV
Board configuration verified successfully.
The CR1 and CR2 LEDs are illuminated
mesa 5i25 card:
W1 - UP
W2 - UP
mesa 7i76 card:
W2 - left --> power pc db 25
W1 - right--> power 24v ext
I run the command:
halrun halcmd: loadrt threads name1=th period1=1000000 halcmd: loadrt hostmot2 halcmd: loadrt hm2_pci halcmd: addf hm2_5i25.0.pet_watchdog th HAL:[b] ERROR: function 'hm2_5i25.0.pet_watchdog' not found[/b] <stdin>:4: addf failed halcmd: addf hm2_5i25.0.read th halcmd: addf hm2_5i25.0.write th halcmd: start halcmd: setp hm2_5i25.0.7i76.0.0.output-07 true <[b]stdin>:8: parameter or pin 'hm2_5i25.0.7i76.0.0.output-07' not found[/b]
What is going on ????
A flashing problem ????
10 years 4 months ago #75985 by andypugh
Replied by andypugh on topic Mesa 5i25 and 7i76
You no longer need to pet the watchdog, it is now self-petting through the write thread.
Try the sequence again, but try "show pin" to get a list of the pins.
The likely problem is that the GPIO system is powered by the field power. With no field power to the GPIO section those pins won't be enumerated.
  • finemeca
  • Topic Author
  • New Member
  • New Member
10 years 4 months ago #75991 by finemeca
Replied by finemeca on topic Mesa 5i25 and 7i76
Hello Andy,
Thank you for your help.
I do :
halcmd: loadrt threads name1=th period1=1000000 halcmd: loadrt hostmot2 halcmd: loadrt hm2_pci halcmd: show pin
Here's the answer :
No reference to 7i76 card
Why there are 24 V or 17.6v to terminal TB5 and TB6 ???
Warning: Spoiler!
10 years 4 months ago #75995 by andypugh
finemeca wrote: Why there are 24 V or 17.6v to terminal TB5 and TB6 ???
You need to wire TB1 to the power supply. (correctly, and carefully).
See page 10 of www.mesanet.com/pdf/parallel/7i76man.pdf
To be absolutely sure you have the correct polarity, pin 1 has a square solder pad.
You don't need to connect all VFIELD, they are commoned on the board.
Look also at the W1 setting and VIN power source paragraph on Page 2.
  • finemeca
  • Topic Author
  • New Member
  • New Member
10 years 4 months ago #75998 by finemeca
I attach a photo of the card.
The black wire is ground TB1
Red is the + 24v
Can there be a malfunction of the card ???
10 years 4 months ago #76000 by andypugh
You could try it with jumper W1 to the left.
Time to create page: 0.133 seconds
