changed P parameter to 1000 (nothing happened
changed setp pid.N.maxerror .0005 to 0 (Nothing happened)
PCW wrote: First thing I would is change the P term to 1000 (was 50)
The wiring looks correct but sometimes the differential outputs do not work very well with high input
current drives so it might be worth trying with common ground wiring (connect PUL- AND DIR- to ground instead of 7I76 outputs and leave the 7I76 dir- and step- outputs unconnected)
You might also verify that the 5V at the 7I76 is not less then 4.75V or so
