What's the PC Spec for Mesa 7i76e ?
10 years 4 weeks ago #81156 by vmihalca
Hello,
I'm in the process of converting my lathe to cnc, finished the mechanical changes and now comes the software.
I'm using stepper motors and an ABZ encoder with 360ppr for spindle.
I saw that Mesa 7i76e connects through ethernet and seems to have all that 7I76-5I25 PLUG-N-GO KIT has
I have already wasted some money on some windows based solutions, so before I order the board I would like to know if there are any special conditions my pc has to meet in order to have this board working at it max potential.
Does the latency matters if I'm using an external board?
Right now I'm using a desktop pc, but with this ethernet board in the future I might use a laptop. Do you guys think a laptop configuration would work with this board?
10 years 3 weeks ago #81248 by Todd Zuercher
Latency does still matter, but the latency requirement is much less than that required for software stepping.
A laptop can work, but I wouldn't recommend it, and most aren't capable of good enough latency.
10 years 3 weeks ago #81409 by newbynobi
This is a latency histogram from an older pentium laptop runnung linuxcnc2.7.7 with UBUNTU 10.04
Latency is pretty good.
I want to use that one for my mill with a 7i76e and I am pretty sure not getting problems.
Norbert
10 years 3 weeks ago #81474 by Todd Zuercher
Remember with an Ethernet Mesa card you have to use a Preempt-RT kernal rather than RTAI. An older single core processor like that might not have enough horsepower to run a Preempt-RT kernel well, and a laptop with all of its power-saving features disabled may run dangerously hot.
10 years 3 weeks ago #81523 by newbynobi
Hallo Tod,
you are so right, here the same Laptop with Wheesy and RT_PREEMP Kernel,
Not very good :-(
Norbert
10 years 3 weeks ago #81524 by Todd Zuercher
You may want to try again, your histogram image, does not show that the preemp-rt kernel is the one running.
Time to create page: 0.062 seconds
