what are the disadvantages of not having encoder index signal on mesa 7i77 card
9 years 9 months ago - 9 years 9 months ago #86948 by reliantkill
what are the disadvantages of not having encoder index signal on mesa 7i77 card?
I am putting a laguna cnc mill machine together and when I finally got to connect the encoder cable to the 7i77 card
I realized that I have only A / B signal coming out of my encoder, and is single ended 500 ppr.
Now what? I am going to need to change the encoders or I can still use them without Index signal
help is encouraged!
the encoder is a BEI L25G-500-AB
This browser does not support PDFs. Please download the PDF to view it: Download PDF
Last edit: 9 years 9 months ago by reliantkill.
9 years 9 months ago #86962 by tommylight
You can use it, of course, the only thing i know will not work without index is rigid taping, if that encoder is on the spindle. It would be nice if you can confirm this, as i am way to long without sleep so i might miss something.
9 years 9 months ago #86976 by PCW
That's correct, you need a spindle index for threading or rigid tapping
also for motion axis, the index allows more accurate homing
9 years 9 months ago #86977 by cncnoob1979
As tommy said rigid taping will not work for the spindle encoder if an index is not available. Also homing using index will not work as well. I have one encoder on my machine that the encoder does not produce an index which is not a big deal. I just use my home limit switches anyway.
I think that is the only "standard use" of index signals in linuxcnc, of course can be wrong. :)
9 years 9 months ago #86981 by reliantkill
My machine has Axis X,Y,and Z with single ended AB channels only. There is no encoder for the spindle yet, that I still have to get one to install it, so I will make sure the spindle encoder has the index signal in it. Thanks for the information.
In the configuration for the 5i25-7i77 does the system will keep on looking for the index signal, will this create an error? and do I have to disable the index signal somehow so the system does not keep on looking for it?
9 years 9 months ago #86984 by cncnoob1979
No it will not. It pncconfig will just create the links to the signal but it will be transparent to you.
This is the setup I use. 5i25/7i77.
Can give you my configuration if it would help.
Time to create page: 2.583 seconds
